My hotpoint washing machine WML 730 G will not spin
Washes but fails to spin
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
barkencoa
  • 3463 Answers
SOURCE: banging washing machine on spins
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Posted on Nov 23, 2008
rpbuice
  • 161 Answers
SOURCE: washing machine will not spin
Check the lid switch.
There are two wires going to this switch, jump these together, if it works then you need a new lid switch.
Posted on Jan 21, 2009
  • 3 Answers
SOURCE: washes but does not spin
your brushes will be worn down and you can cange them you self just remember to unpug machine first remove back panel and 2 13mm motor fixing bolts disconect wiring and remove motor different brushes were used by hotpoint you will need to identify them good luck
Posted on May 14, 2009
sodeep
  • 3267 Answers
SOURCE: Hi, my Hotpoint Aquarius wma56
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Posted on Jun 10, 2011
Hotpoint wml 540 spinning but water not draining
Hi
It seems likely that your pump is either blocked or faulty. It could also be a blocked or kinked drain hose.
You haven't nominated a model.
Good luck.
Nomess
Aug 30, 2014 | Hotpoint Washing Machines
Hotpoint wml 730
Sounds like it could be an unlevel washer. That is one thing to check.
Make sure the filter is clean. The filter is located behind the kick panel and will be a screw in filter. You will need a shallow bowl or pan to catch the excess water. Clean the entrance for the filter is clean and free of dedri.Make sure to unplug your machine before this procedure.
There are other problems it could be but, lets try this and see if it helps.
Aug 27, 2014 | Washing Machines
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
Why does my hotpoint aquarius WML 720 will fill up but will not wash where would the filter be
you may have a bad door switch should check with a multi meter. can also check ur water pressure switch and motor coupler or belt if applicable
Jul 13, 2014 | Hotpoint Washing Machines
Hotpoint WML 730
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Nov 21, 2013 | Washing Machines
Hotpoint wml 730
use hotter water.
Sep 20, 2013 | Washing Machines
I have no power to a Hotpoint Aquarius washer, Model WML 730. Is there a line fuse and if so where is it?
Chance is its the two pole off/on switch or door interlock , check switch first.....
Mar 03, 2011 | Washing Machines
My hotpoint wmm39 aquarius extra washes but does not spin
you are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Sep 25, 2009 | Hotpoint WMM39 Front Load Washer
Washing Machines Logo
208 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
