ERROR CODE E15 HOOVER OPHS 712 DF - Washing Machines
5 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Posted on Aug 01, 2010
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
  • 6277 Answers
SOURCE: I have purchased a hoover
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 12, 2011
  • 6277 Answers
SOURCE: Hoover OPH 617 DF 1600
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Aug 17, 2011
Error code e15 showing
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Dec 19, 2015 | Hoover Washing Machines
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
E15 error hoover
my washing machine HOOVER DST 10146 P is showing error code E15 what does it mean and how to fix it?
Jan 03, 2014 | Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
I have purchased a hoover ptima oph 714 df without a manual where can i get one?
Manual
John C.
Aug 12, 2011 | Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
