Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not stay down.
Just started to happen. Adjusted the settings on the motor for up and down with no results. Could it be the electric eyes out of alignment?? And if so, how do you get them aligned again??
  • msmike Feb 04, 2009
    Where is the travel adjustment on the garage door?
    Champion:
  • 244 Answers
If it were eyes, doors would open and light bulb would flash ten times. sounds like travel adjustment needed to be peaked.
Posted on Jan 22, 2009
Door starts down then stops eyes are clean and aligned . i adjusted down force some. changed baterries and wall switch nothing helped
Disconnect the door opener from the door and insure the door easily goes up and dow
with your hand. It may be binding.
Good Luck
Feb 01, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a Chamberlin GDO 1/2 hp. The white wheel on the sprocket assembly had the teeth worn down. I replaced it according to instructions. I reassembled the motor pieces and tried the opener. I have...
Someone else can join in, but I think when it only moves that little, it has to be the RPM sensor. It may be installed correctly but the electric eye that "sees" the vanes turn may be dirty. Clean that out. I'll try and add the picture, or try here:
http://tinyurl.com/gearfix
Jan 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener and I have to hold the button down in order to close the door. The door opens fine and the sensors are clear. The unit starts to close then stops, the lights start...
When you can close the door by holding down the wall button it IS the safety eyes or wiring.
If the eyes are mounted to the track. Many times the track wll move as the door closes causing the eyes to move out of alignment.
Watch as the door moves down and see if they need to be adjusted.
If the eyes are not both lit - they are out of alignemnt or have a wiring problem. try adjusting them and see if the lights come on. - if not check the wiring
Hope this helps
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
1/2 HHP lift master. the motor acts like something is in the way
I am assuming the door wont close.
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Garage door will not stay down it just started .. it looks like the chain is loose could this be the problem
If the main light is flashing 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each sensor is on and not flickering.
If the door reverses but the main light does not flash it could be a bad RPM sensor which is a small circuit board just in front of the motor.
If the door is hitting the floor and then reversing it is traveling too far. On the side of the motor unit you will find the 'down limit' control. Turn this a bit in the opposite direction of the arrow printed on the cover.
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master GDO goes up, not down
If the door operates freely without any binding, while operating it manually then It would appear that the obstruction sensor mounted across the doors path is ether out of alignment, lens dirty,or malfunctioning
Feb 21, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
161 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
