Question about Lorex Home Security
Don't have a receiver for a MC7302 wireless camera how else can i use the camera
Can i hard wire the camera MC7302 with rca wires
tech240
  • 169 Answers
SOURCE: bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Posted on Sep 20, 2009
  • 272 Answers
SOURCE: i cannot get the rca speaker wires to produce
the rca speaker hook ups are there to carry a signal to an amp and the amp to put a signal out to your speakers so with that being said you will not get sound out of them due to the fact that it carries a real real low power signal
Posted on Feb 24, 2010
joemxavier
  • 342 Answers
SOURCE: internet signal not passing through to desktop or wirelessly.
This can be fixed by resetting the modem,the ip address,other setups.
Posted on Jul 05, 2010
heatman101
  • 43501 Answers
SOURCE: I have an AO Smith
Here is the connection diagram...
Low voltage would be if you are using 208/240v and use the high voltage if you are using 460v
3 phase motor connection
heatman101
Posted on May 18, 2011
martindeang
SOURCE: i don't have a grounding wire and don't know what to use!
You only need to ground the turntable..or arm.. if you have any hum.
If you do have hum, take a length of wire from a suitable fixing point - must be conductive ,of course...most T/Ts are plastic eeugh these days...so some metalic part at the arm base is most effective and take this to your amp and connect. Has the hum gone?
Most high end turntables had the arm and chassis connected and the earth was usually run along with the phono connectors to a dedicated connector next to the phono input on the pre amp. Often it was recommended only the pre amp be physically earthed to ensure no loops and consequent hum.
Posted on Jun 17, 2012
Would like to rewire Astak CM-918 camera due to missing hardware
Red and black, are power; white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
Nov 26, 2013 | Astak Home Security
Wiring a back up camera
Try the truly wireless QuickVu(TM) Wireless Backup Camera. The camera has no (zero) wires, so it installs simply. The receiver and monitor mount easily on the dash, or if you have an in-dash screen with an RCA input, simply run a cable from the receiver to the screen. Buy direct from the manufacturer!
Aug 18, 2013 | 2001 Lexus LX 470
Have sony xav-60 head unit trying to install a rear view camera, but having issues getting unit to switch over when in reverse what wires need to go where camera has yellow video output 1 red wire, 1 black...
You might try the truly wireless QuickVu(TM) Wireless Backup Camera. Run the yellow RCA cable from the receiver to your Sony unit, if it has an RCA input. The QuickVu camera has no wires, so that part is really easy. Buy direct from the manufacturer!
Aug 12, 2013 | Sony XAV-60 Car Video Player
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
Can i hard wire my rt 2770 rca home theater subwoofer to my receiver lost white plug that plugs into receiver and can't find a new one?
I have one if you still need it. Hooked my sub up to a different receiver and cut that end off to hard wire it. It has about a foot of wire and the white plug on the end that goes into the receiver.
May 11, 2012 | RCA home theater system RT2770 User Manual
How do i upload my photos wirelessly
You don't.
The Vivitar 8025 is a low cost, basic model and so does not support any kind of wireless data transfer. Use wires only, or far better still remove the memory card and insert it into an external card reader.
Jul 22, 2011 | Vivitar ViviCam 8025 Digital Camera
I have an old kenwood kac-801. It doesn't have rca outputs. i have an output adapter but the wire colors are different. i need the scematics or someones help
take one of your door speakers and check the wireing on the speaker and hook up your wires to those wires on your raido
May 12, 2010 | Car Audio & Video
Kenwood KDC-X590 CD Player
what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
Aug 12, 2008 | Kenwood KDC-X590 CD Player
Home Security Logo
35 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
