Question about Samsung RS2630SH Side by Side Refrigerator
Water dispenser not working all the time
I have a Whirlpool frig and the water dispenser in the door has stopped working. At times it will work so the line in not clogged. At times, when you press the cup handle in you can hear the motor kick and then water will come out. At other times, you press the handle in there is no sound and no water comes out. Is there a switch failing or something else? The ice dispenser is working the whole time. Ideas?
Thanks,
Darryl
  • 31 Answers
I think you are correct that its the switch that the push bar hits is faulty. Try a serch on line for applince parts and enter you make etc. This should provide a break down of the part and a idea what is needed to take apart/off to get to it.
Posted on Jan 20, 2009
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No light on water dispenser
'After about ten months, the water dispenser stopped. I found a 5/16" coupling below the freezer door. Following the instructions on a tab attached to the hose, I separated the hose from the coupling. I then actuated the water cradle. Water gushed out of the tubing. The dispenser side of the dual water valve is ok.
I snaked a wire into the hose toward the dispenser until it stopped. I withdrew the wire then measured the length. The hose had a blockage at the lower left edge of the dispenser opening. I didn't know if there was a check valve in the hose. Since it was still in warranty (2 months to go), I called service.
I didn't say anything about what I did to the tech. He concluded that the hose was frozen (there is no check valve or anything else in the line between the coupling and the dispenser). According to him my options were to replace the door (he actually said that) or shut down the frig and let it defrost. I fabricated a double layer cardboard cover for the freezer compartment. I removed the light bulb then covered the opening. In about 60 minutes the dispenser started working again. I have had the frig since 12/03. It just froze up for the sixth time today (3/20/07). GE has offered no help or acknowledging that the frig has an insulation problem.'
Jun 20, 2009 | Frigidaire FRS6R5EMB Side by Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
119 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
