Question about Electrolux Washing Machines
Change door seal on EWF1090 electrolux washer
gittos73
  • 244 Answers
SOURCE: door seal hotpoint 9540
undue the screws oat the back that hold the lid in place make sure washer is unplugged now open the door undue the clip that holds the front part of the door seal on this maybe a spring clip hidden under the edge of the seal or there will be a plastic clip remove and pull the clamp away now looking from the inside through were you have taken the lid off look to the back of your seal there will be a screw clamp un-screw it door seal will now pull out reverse this order to put new seal on m8
Posted on Sep 24, 2007
  • 13 Answers
SOURCE: ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Posted on Apr 11, 2009
  • 6 Answers
SOURCE: My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Posted on Dec 05, 2010
  • 10865 Answers
SOURCE: electrolux ewf1090 service manual
hi hea..... here you go http://www.manualsonline.com/ex/thread/view/idThread/4898
Joe
Thanks for choosing Fixya!
Posted on Dec 16, 2010
  • 146 Answers
SOURCE: Electrolux EWF1090 front laod washer
e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
Posted on Jan 26, 2011
I have an Electrolux ewf1090 front load washing machine, about 7 years old. Tried to turn it on. Everything seems fine, all lights and buttons work, but when I press the start button nothing happens. What...
Good Afternoon Simo, thank you for allowing me to assist you. Let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further.
Aug 27, 2013 | Electrolux Washing Machines
Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
Jan 26, 2011 | Washing Machines
I have a ewf1090 with an E40 error what can I check to see what is wrong
The code E40 indicates an internal loss of power, most likely caused by the door not been properly closed, either by a handling mistake or because the door latch is worn out.
There are a number of other conditions that may pop up the same message (i.e. overload due to defective motor, fuse blown), but unless you have any other symptoms like burned smell, I'd go for the door first.
The fuses are the second thing I'd check.
Jan 02, 2011 | Electrolux EW1000i Front Load Washer
My Electrolux EWF1090 is having problems, on the tiny screen it keeps comming up with "E20" i dont know what that means and how to i get it to work?
go to www. Electrolux.com.my/files/malaysia_singapore/manuals/fabriccare/ EWF1090.pdf this will give you the manual with all the information to solve this drainage problem
Nov 14, 2010 | Washing Machines
Apr 25, 2010 | Electrolux Washing Machines
How to change door seal on electrolux ewf1087 frontloader
My electrolux EWF1087 is leaking water from the front door, I cannot see any damage on the door seal although I never noticed its folded over and full of dirt. Do I need a new seal ?
Oct 03, 2009 | Electrolux Washing Machines
Apr 11, 2009 | Electrolux Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
