Question about Lexmark Z2420 Printer
Better way to conserve ink?
So i recently chatted with the Lexmark techs and found out (according to them) that there is no way for me to print black and white photos using the black ink cartridge only. I am finding that when i select "best quality" and print like a 5x7 photo, I am losing almost 1/4th of my color cartridge. All of that for a measly 5x7 photo? Does anyone have any advice? Am I possibly not setting the appropriate options or did i receive a super crappy printer when it comes to photo printing. I mean I realize it's kind of lower quality, but never had I imagined I'd be running through color ink so quickly. Any suggestions would be helpful. Thansk so much guys!
    Genius:
  • 2,120 Answers
Sad but true. This is how printer mfgrs make their money...selling ink.
It's cheaper to take your photos on a memory card or CD to CVS Pharmacy and have them printed
Posted on Jan 20, 2009
My printer has not been used in a few years and it is not printing now.....do you think the ink is dried out? If I only purchase the black ink....will it work?
ink drys out quickly and yes years means its dry.
no you can't just buy a black and make it work. lexmark requires working color and black if the printer prints for both. kinda an unfortunate thing. honestly i suggest getting a kodak printer. tons better than a lexmark and the print is the cost of your 2 ink carts. also the ink for kodak is ~30$ usd total for both black and color not just one of them.
Jun 29, 2011 | Lexmark X2470 All-In-One InkJet Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
How do i mix the colours on my stylus sx115 as i have run out of black but have the other 3 colours remaining?
Conserving Black Ink When the Cartridge Is Low (For Windows Only) The window below appears when black ink runs low and there is more color ink than black ink. It appears only when plain papers is selected as the paper type, and Text is selected as the Quality Option.
The window gives you the option to either continue using black ink normally or conserve black ink by using a mixture of color inks to create black. Click the Yes button to use a mixture of color inks to create black. You will see the same window the next time you print a similar job. Click the No button to continue using the remaining black ink for the job you are printing. You will see the same window the next time you print a similar job, and again have the option to conserve black ink. Click Disable this feature to continue using the remaining black ink.
Oct 16, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Print in Black ink only?
Go to "Start" "Settings" "Printers and Faxes" choose your printer in the menu window,,right click and bring up sub menu,,then choose properties,,you can change all of your printer settings from here.
Jan 19, 2009 | Lexmark Z2420 Printer
Just bought lexmark model X2600m, thought it was black/color printer/copier/scanner but seems it is only color, is it suppose to print in black and color or just color????
i have one too but you have to but the ink online because it is a fairly recent model.
the ink is number 14 black i believe.and it does print in black.you dont need black ink to print in black altho is does guzzle colored ink when making black.ink is about $20 +shipping i think.
link:http://www.lexmark.com/lexmark/product/home/644/0,6970,204816596_653293766_1189421700_en,00.html?tabId=7&func=rewsupplies&prtr=4433001&lang=0&ctry=00000409&src=10
Jul 29, 2008 | Office Equipment & Supplies
After refilling cartidge it still says it is empty
IB4G2008: Do u actually have a solution or a better driver for this printer OR are u just out to promote your site?
Your solution is not helping & if u think it is, pls oh pls,let me know of a DIRECT link for it, as i havent found anything that makes the problem better, nor a better driver for that particular printer.
Pls advise.
eldiablo2008
Jan 23, 2008 | Lexmark Z1420 Printer
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark Z2420 Printer Logo
89 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
