Question about LG LRTN19320 Top Freezer Refrigerator
Loud thump from refrigerator when it shuts off???
When my refrigerator shuts down it makes a loud thump ? What could this be???
  • vblong Jan 20, 2009
    Thanks so much . I was wondering if it is dangerous ? Also would this be expensive? So it dont hurt the refrigerator to do this?
    Thank you,
    Vicki
    Thank you so much! I will check the level of it ok? You have been a great help. Glad to know I dont have to worry so.
  • 31 Answers
If its a rattle, kind of a shake sound that ends in a phthump then its the compressor moving around after it has removed the heat from the unit. You may want new rubber mounts but I would leave it.
Posted on Jan 20, 2009
  • gvince4
    gvince4 Jan 20, 2009
    Nope no danger, it would be like $10-30.00 for parts and then the hour charge + travel time for the tech to come out. It wont hurt the unit. I would also see if its level side to side and front to back. If its close then leave it.
REFRIGERATOR MAKES A LOUD VIBRATING NOISE WHEN SHUTTING DOWN
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
May 19, 2011 | Kenmore Refrigerators
Model ctx24ga when compressor shuts off it makes loud sound like a air lock ??
heatman101
May 04, 2011 | Hotpoint Refrigerators
My Kenmore 61182100 compressor makes a couple of loud bangs when it shuts off
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
Jan 29, 2011 | Kenmore Refrigerators
It makes a thumping noise when it stops running.
As the manufacture says to us techs, get used to it, sorry thought I would throw that in there. This is a common complaint, it thumps once or twice shortly after it shuts down. What is going on here is this, your frig will run til it either reaches the temp you have set or til it's time to go into "defrost" mode (does this about every 8-12 hours of actual run time)", then it will shut down, turn a "heater" on inside the evap area. The sudden change of temp causes a "thump" noise. They have changed these boxes up due to energy requirments, so the have to make the heater a little hotter so that it does its job quickly and then shuts off. Now, you need to make sure that the thump is not right after it restarts, if it is then you have a "dryer" that needs to be covered and the screw removed from the side of the cabinet where it mounts. Sudden expansion of the cold freon in the dryer causes a thump also, removing the clamp, sliding the dryer over a little will normally cure thump.
Oct 09, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
LG LRTN19320 Top Freezer Refrigerator Logo
1,330 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
