Question about Refrigerators
My Defy double door fridge/freezer makes a singing noise. When I open the freezer and press the plastic button, it stops
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
watugot
  • 290 Answers
SOURCE: kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Posted on Apr 12, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
SOURCE: I have a Samsung Waltz
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Posted on Oct 15, 2010
I have a Servis fridge freezer and it's making a clicking noise at the front at the top. Fridge and freezer working but noise annoying . Stops when u open the door. What is causing this.
Does it have a fan? If so fan may activate when the door switch closes. Open the door and hold switch then and check for noise.
Jan 20, 2016 | Refrigerators
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
My double door firge frezeer is not icing and the red alarm button is alarming all the time
Glori,
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
Sep 14, 2010 | Samsung Refrigerators
Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
Mar 04, 2009 | Refrigerators
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Vibrating noise from freezer/fridge?
Mar 28, 2008 | Refrigerators
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
