Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
One inch black band with copying
The copy is not cut off but a black band appears down the side of each copy or scanned document. Printing from internet or Word documents are perfect.
  • 31 Answers
I think the scanner has crud or dust on the reader. You likely want a "pro" to clean it.
Posted on Jan 20, 2009
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Copies and faxes come out with 5 inch black area over whole page
Does this same thing happen if you just print a report out of it?
Here's the logic behind this.
If it happens on scanning or copying, but not on printing that's a problem with the scanning section.
If it happens on everything (scanning, printing etc) that's a problem with in the printer controls.
Usually on lasers, if it's printing related, the first thing to do is change the toner.
If the imaging drum (which is part of the toner cartridge) is damaged, it will leave lines down the page.
This is a fairly common problem on refilled toners.
If you have changed the toner, and it still does it, it's a different problem.
Aug 11, 2008 | HP LaserJet 3015 All-In-One Printer
When I want to copy a page it cuts off about 1 inch on th e side Have tried everything I put it on the glass like it says and no luck
i think all printer with copier have in common in regard with copying the have all allowance i think its half an inch so if you copy a borderless document its not 100percent copied theres a cut on the side. My solution? scan and edit so you can have a complete picture without a cut.
yours,
alecz
Apr 23, 2008 | Office Equipment & Supplies
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
