Question about AOC Computers & Internet
My aoc monitor screen adjustment " contrast/brightness tab " pop-up and can hinder my sight.. what should i do to fix this problem?
My aoc monitor is a crt monitor
SOURCE: CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Posted on Oct 17, 2006
  • 238 Answers
SOURCE: brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Posted on Dec 15, 2007
  • 400 Answers
SOURCE: My Monitor AOC CRT Model F1770 is always adjusting
Try to unplug the power cable from the mains for about 10 minutes then replug and try again.
Make sure all cables are well connected.
Try to test it on another computer if possible.
If that doesnt help then it sounds like a hardware problem with the monitor and you wont be able to repair it your self.
Posted on Jul 24, 2009
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
  • 72 Answers
SOURCE: my monitor pops up the contrast menu without doing anything.
Actually the button for setting the contrast is a bit loose thats why whenever their is a **** os little movement in the moniter opf ur PC then the contrast button get pressed automatically and the pop up comes up
Posted on Sep 07, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
MONITOR VT17N71, SN C0542C0739 I CANNOT GET THE RESOLUTION THAT I THINK THE SCREEN SHOULD HAVE. I'VE TRIED ADJUSTING THE BRIGHTNESS...BUT IT'S ALWAYS TOO BRIGHT. I'VE TRIED ADJUSTING THE CONTRAST,...
Hi.
Just a general suggestion.
Are the graphics drivers loaded.
(Assuming you are using Windows) what happens when you rightclick on the desktop screen and you click on the Settings Tab
Jan 06, 2010 | Soyo Computers & Internet
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Computers & Internet Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
