Question about Yamaha YAS-101 Front Surround Sound Bar System with Optical and SPDIF Cables
Remote control code for Yamaha 101 sound bar
Would like to use the TV/Cable FIOS remote to power on/off the sound bar
bbtoast
  • 319 Answers
SOURCE: remote code
This can be a frustrating process! I have had similar problems in the past, but perseverance is key!
Please be sure that you did all of these tricks:
1 Be sure to press and HOLD down the appropriate input button while pressing the AV power button for 3 full seconds.
2 Enter the code. Unfortunately, you may have to try all of the codes listed for your manufacturer. There are 23 for Phillips! There are "only" 8 for RCA, so you might try that compnent first.
It sounds like you are doing the right things, but is it possible that you are accidentally hitting a wrong button during the process? ie; using the TV power button instead of the AV power button? After completion of the task, are you then hitting the proper component button, such as DVD before trying to use the remote to control that device?
I apologize if you have tried all of these things, but I am not sure of your level of expertise! Good Luck!
Posted on Jan 01, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
smarthome2
  • 1114 Answers
SOURCE: what is the yamaha htr 6050 remote code?
You have to "learn" the IR. Yamaha has discrete on and off commands. which universal remote are you using?
Posted on Jul 26, 2009
perpetually
  • 360 Answers
SOURCE: I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Jul 13, 2010
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Remote control code for Logic 3 Tx101 soundstage 5.1
Your Yamaha soundbar may work only with its own remote. Otherwise, the soundbar signals could interfere with the TV remote signals. You can try searching with your universal remote to find a code that will work.
Aug 10, 2014 | Yamaha YAS-101 Front Surround Sound Bar...
Can't program comcast remote to yamaha yas-101
The only thing i was able to do was to use this link and make the remote learn the functions by following the instructions on the Yamaha web site for the sound bar to AUX. YAS 101
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/
I then used the instructions below to volume lock the aux so that i did not have to switch back and forth from cable to aux to adjust volume and change channels
Setting Global Volume Lock
Global Volume Lock will force the volume and mute keys to be controlled by one device.
  1. Press and hold the "Setup" key until a device key blinks twice.
  2. Type in the code 993. A device key should blink twice.
  3. Press and release the device key for the device you want the volume locked to.
  4. You will get two blinks if the lock is successful.
Jul 03, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Yamaha YAS101 sound bar does not work on DirecTV remote control
Try this solution:
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/?current_page_id=1&sort=undefined&type=
Jun 22, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Coby tv code for fios remote
1. Press and hold the TV key. 2. While holding down the TV key, press OK. 3. Release both keys. The Device Keys will blink twice.
Ideally we do not have code for coby TV. So we need to manually program the remote
TV and Cable box should be both powered on.
4. Press 9 - 2 - 2. 5. Point the remote at the TV. 6. Press PLAY Press FAST-FORWARD. Every time you press FF the remote sends out a new power-off command to the TV. Keep pressing FF until the TV turns off. (You can press REWIND to go back 1 code.) 8. When the TV turns off, you have found the right code. Press OK to store this code. 9. Press TV and the power should go on. You will now have volume control also.
TIP: Press ff slowly so you know when it powers off and when you need to save the code by hitting OK after it powers off.
Jan 02, 2009 | Coby TF-TV1901 19 in. LCD Television
Master volume to high
what kind of tv is it i work for fios and am willing to help you.
Dec 03, 2008 | iLO 3200 32 in. LCD Television
Fios Remote Code for Yamaha SOund Projector
call the 888-553-1555 that is the fios solutions center
Nov 20, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Yamaha YAS-101 Front Surround Sound Bar System with Optical and SPDIF Cables Logo
341 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
