Question about Dayton E51 Oil Filled Utility Heater
Are parts available for a dayton model 3e219c
Black plastic piece with air screw is cracked
  • 181 Answers
If the back plastic piece is cracked it is no good,replace it with a new one.should also change the filter at the same time....inside the plastic piece there is a steel ball and a spring....also good idea to replace them also..if this unit has a glow bar you ill need to adjust the air pressure to the correct setting.if it has a spark plug the adjuster goes in jst past flush....there is a slight bevel in side that you should be able to see.
Posted on Feb 23, 2009
Dayton ready heater model 3e219c will not light
First make sure that th eunit is getting spark and the spark plugs is to gapped at .070 to .080 also you need to make sure that the air pump is working on the back of the motor.
Also inspect the black plastic cover for cracks.
Jan 08, 2015 | Dayton Heating & Cooling
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Need wiring Diagram for a 3hp motor model #5K967M made by Dayton
Dayton is a product of Grainger Industrial supply. You can contact Product Information and Parts Help at 800-323-0620 or their Tech Service Dept at 888-361-8649. I'm sure they can help you. Just have the Model Number and Serial Number available.
Mar 08, 2011 | Dayton Heating & Cooling
Motor burned out need a replacement motor. Where can I buy one?
USAVACUUM.COM has all the hoover parts available for the H3000. The part number is 59177074. Follow the link below to your model number.
http://www.usavacuum.com/category-s/85.htm. .
Thanks. Please leave positive feedback.
Mar 13, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I have a Dayton 110,000 BTU need back plate
Look up Grainger or WW Grainger on the web they should be able to help you find the part.
Jan 06, 2010 | Dayton Gas Furnace Heater
I need a rotor pump and blades for a dayton 150,000 btu heater model number 3e219c
Lots of time if you clean the blade area and remove the thick gunk from around the cover and housingand replceblades this should do the trick...
Dec 16, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Paying for part for LCD 4010 NEC MONITOR (MODEL: L404G6)
If you can't find the part, glue the crack with ABS pipe cement or liquid plastic model glue (use a toothpick to apply it to the crack from the inside of the part). If the crack is still displeasing to look at, hire a starving artist to make an inlay or custom trim piece to cover it up.
Apr 25, 2009 | Televison & Video
I have a yellowMiele Vacuum,model=Electronic Air Clean Plus S3121. On the main body the part that the pipe/nozzle clicks into has a piece that has snapped off. I can see this by lifting the lid and the...
Generic problem for all Vacuums
posted by maura497 on Apr 18, 2008
Report abuse
I have a yellowMiele Vacuum,model=Electronic Air Clean Plus S3121. On the main body the part that the pipe/nozzle clicks into has a piece that has snapped off. I can see this by lifting the lid and the black plastic piece that is screwed to the inside of the lid has a piece chipped of it which means that when the nozzle is clicked into place it is completely loose. There is a black piece that clicks into the inside of the hoover into this broken part which is still ok so at the moment by lining up the nozzle with this loose piece I can click it into place. How can I get this piece that I need?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can order the order or the schematics from the factory website listed below and I will provide you with another contact as well for the Miele S3121 in order for you to order or replace the part that is broken or you can refer to your local vacuum cleaner dealer in the yellow pages.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430 they can also mail or fax you the info needed to repair or replace the part and they will ship out the product as well
Apr 18, 2008 | Vacuums
Dayton E51 Oil Filled Utility Heater Logo
246 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
