Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
Why the ice cubes stuck together in fisher and paykel fridge
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
Posted on Mar 31, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
  • 3 Answers
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Posted on Nov 07, 2009
Ice forms as large block not in cubes
Defrost thermostat is bad. Defrost element is staying on for too long raising up temperature causing ice to melt.
Mar 26, 2014 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
My 3mth old e522brxu fisher and paykel ice maker has stopped working water is working fine you can manually force a dump and hear the cycle start to turn the tray but no water fills the tray can not hear a...
Hi, For the benefit of anyone doing a Google search for it (which is likely anyone with a Fisher and Paykel fridge w/icemaker) the broken wire is a notorious design flaw, and if you see it dangling from your ice tray - symptom is no ice being made -
You must remove the clip underneath the ice tray, and a little foam pad with it. There you will see the broken wire attached to a little black sensor. It's a little fiddly to do in place, but after unplugging the fridge (unless you like a good electric jolt) you need to splice the wire and reattach it. Your ice maker should resume working as intended.
Hope that helped.
Good luck.
May 26, 2011 | Fisher and Paykel E522BRXU Fisher & Paykel...
Hi, I have a fisher and paykel fridge for almost 3 years.The problem is that the ice cube maker stop working. I have check all the things that are mention in the fridge guide, water supply is fine, the ice...
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
Jan 29, 2011 | Fisher and Paykel Active Smart E522B...
I have a Fisher & Paykel Refrigerator. The ice cube maker has stopped working and the 'force cycle' does not make the ice cube tray 'flip'. Any ideas?
Hi! The refrigerator has dual valve with two coils at the back and the ice side may have gone bad thats why it doesnt make ice. YOu will have to have it replaced to get your fridge back to its normal working condition. Hope this helps and have a good one!
Aug 03, 2010 | Fisher and Paykel Refrigerators
Oct 04, 2009 | Fisher and Paykel Active Smart® E522BR...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice maker dumping ice before it's frozen
Please call your Manufacturer for Warranty!!! You pay a great deal in the cost, so you should not hesitate to call.It will cost you ZERO $ PLEASE RATE THIS ! THANK YOU!
Jun 06, 2008 | Fisher and Paykel Active Smart E522B...
Ice maker broken
check to make sure the arm or what ever controls the cubes isn't stuck closed or the inlet to the maker isnt' got some restriction
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
35 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
