Question about Hobart Dishwashers
Ecolab soap dispenser for dishwasher not working
Sanitizer is not dispensing, it has auto feed
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
SOURCE: Soap dispenser still has the soap in it after the dishwasher cycle has ended...
do you have a salt unit fitted. I had the same problem and the repair guy had to replace the salt unit as it was blocked up. Failing that it might be the board not opening the solenoid to allow the water to be jetted through the soap dispenser.
Posted on Mar 16, 2008
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
  • 135 Answers
SOURCE: soap dispenser does not close
Make sure the dial is at the start positon and not in between on some other setting.
Posted on Sep 05, 2009
Hobart dish machine. We were told by Ecolab tech that we need to rinse off all presoak, soaps and sanitizers before passing through the maching as they cause foaming/excess suds. I do not find that info...
That's true. excess of foam can cause poor wash pressure and poor final rinse.
Operation manual , pag.24. (F17791Rv02-06.pdf)
DO NOT exceed chemical manufacturer's recommended concentrations for detergent, sanitizer, rinse aid or lime scale remover.
Mar 13, 2015 | Hobart Dishwashers
#FDB1500LFB2 does not dry dishes after sanitize
Hey friend, I appreciate your post!
From my understanding your Frigidaire dishwasher, FDB1500LFB2, is not drying dishes after the sanitize cycle. Check to make sure the heat dry option has been selected on your dishwasher panel. I would also check to make sure that the rinse aid dispenser has been filled.
Assure that the temperature going into your dishwasher is 120 degrees, which you can verify by using the sink closest to your dishwasher. If all of that checks out I would suggest seeking assistance from a professional for further diagnosis and repair. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire Dishwashers
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
To clean can I 1) hose it down with a dishwasher
This isn't recommended, meat tends to get in a lot of the nooks and crannies in a slicer machine. It's best to first unplug the machine, then take it a part in order to properly clean it. If your not sure how to take the machine apart, consult the user's manual for further understand how to do it. Once taken apart, some sort of stainless steal cleaner followed by a sanitizing soap should be used to clean it. Sanitizer is very important especially when dealing with meat products. Once a sanitizer is applied it is recommend that you let the slicer air dry for 4-6 hours before using it again to ensure the sanitizer has fully dissipated.
May 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
How do I open a wall mounted Purell NXT hand sanitizer in order to put in a refill? It appears to hinge at the bottom and open at the top, but it doesn't want to open easily and I don't want to break it....
It's been a long time since you asked, but in case someone else found your question like I did, here's the answer:http://www.marketlabinc.com/product.asp?P_ID=4110
There's a release button behind the hinge!
Feb 20, 2011 | GoJo PURELL NXT SPACE SAVER Hand Sanitizer...
The soap is not coming out of the auto dispenser hole and it is full and has been
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 14, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
GE Profile side by side. Water flow at door dispenser is slooooow. Replaced filter - no joy, replaced solenoid, still slow. Now I have narrowed the problem down to the feed/return lines to/from & the...
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
Sep 25, 2010 | GE Refrigerators
Dishwashers Logo
195 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
