Question about Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have a Samsung SyncMaster 215tw that the screen recently went "black" on. If I press any of the buttons on the monitor (menu, pip, etc.), the screen occasionally displays for about 1 second, then goes out again. I checked the connections, but since the menu doesn't even display, I think it is the monitor. Oddly enough, after pressing the menu button, there is a dialogue box that displays and states the monitor tested good, then it quickly disappears.
In the event my suspicions are not correct, here are the other things I've done. I've checked the cables to make sure they have not come loose. I didn't swap them out, as they are the only DVI cables I have. I rebooted the computer, and the screen displays for 1 sec when the boot loader displays the options for booting. I've also turned off the monitor via the switch on the back-side and underneath of the monitor where the power plug connects, and I completely removed the power chord also (based on a suggestion I read to another issue someone was having with this monitor). Nothing has worked thus far. My video card has only a DVI connection on it, so I was not able to connect another monitor to the computer to verify it is the monitor, as the 215tw is the only DVI monitor I own.
Thanks in advance for your help.
  • fxt2 Mar 13, 2009
    a lot of people seem to be having issues with samsung 215tw screen flickers / going black at the moment - bought mine in march 07, and it's worked perfectly until now.... It seems to be something to do with the power, I think... because it's connected to how it responds to being booted up. And it seems to get better the longer you leave it. The flashing varies, and on mine it seems to be brighter on the right hand side of the screen.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Posted on Feb 01, 2011
Samsung syncmaster 215tw will only display faint blue screen-no images.
Check for a failure of the capacitors on the power supply board. This is a common problem with these units and its a very easy repair. Here is a link to a repair guide for the SyncMaster 214T which uses the ame power supply board so the repair information would be the same for the 2 units.
http://www.ccl-la.com/blog/index.php/samsung-214t-repair/
I hope this helps,
BuddyMc
Jun 07, 2012 | Samsung 215TW SyncMaster 21" LCD Monitor
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
How do I get sound from my new Samsung monitor. Everything works fine.
Here is the user manual: http://www.retrevo.com/support/Samsung-215TW-Monitors-manual/id/278ag702/t/2/
Just get an audio cable with mini stereo phone plugs at both ends, attach one end to the PC audio line out jack (Green), the other end just goes to monitor audio line in jack (green).
Apr 01, 2010 | Samsung 215TW SyncMaster 21" LCD Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung Syncmaster 225BW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
Samsung syncmaster 226BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung 215TW SyncMaster 21" LCD Monitor Logo
1,036 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
