Home | Sony | Cyber-Shot DSC-P92 Digital Camera | Power on for file vie...
Sony Cyber-Shot DSC-P92 Digital Camera
Problem for Sony Cyber-Shot DSC-P92 Digital Camera
Power on for file viewing and setup, but not camera or video.....
By idontcareabo on Jan 20, 2009
When I press the power button, it comes on, but only if I have it set to the "Play" button which lets you brows your pictures; or if I have it on "Set Up"
If I switch it to the camera or the video options, it immediately shuts off.
The camera went several months without use, sitting in a drawer. When I tried to use it again, this was the problem I was presented with.
Any help would be appreciated.
Same Problem
May 20, 2009
-   Same problem, power on for file viewing & setup only. Shuts down when put on camera or video. Also noted that have a flashing red LED where memory card plugs in. New and/or different batteries make no difference. Since this 1st occured problem has escalated to not coming on for any setting, however LED continues to do a fast flash. Reset button has no effect on camera itself or LED, though LED ceases to flash as long as reset button is held down. Was such a good camera, how could it just up & die for seemingly no good reason?
ANY HELP OR EXPLAINATION OUT THERE FROM ANYBODY?-   HALAXWOOD2
Jan 22, 2009
-   i have the exact same problem; camera only stays in the 'view pictures' or 'set up' mode, as soon as i turn to camera or video thing, it turns off.
recharged the batteries; still same problem...
-   vedder83
Solution #1
posted on Jan 25, 2009
Somewhat Helpful)
vedder83
Rank: Apprentice
Rating: 75%, 1 votes
follow up... try going with a different set of batteries all together. i swapped the sony ni-mh batteries with a generic brand of nickel-metal hydride batteries and 'camera' & 'video' mode are working once again.
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-Shot DSC-P92
Questions and Unsolved Problems for Sony Cyber-Shot DSC-P92
Do you recommend Sony Cyber-Shot DSC-P92 Digital Camera?
Answer
Answer
Hello There, I need to buy memory card, right now I have 126MB, which one should I go for ?
Answer
sony cybershot camera will not recognize the batteries. I thing there is a piece missing on the... (More)
Answer
batterys run down and camera loses its time reference is this normal?
Answer
what are the problems if any with the sony cyber shot
Answer
the lcd work fine but when you go into camera or video recorder mode the lense does not see anything... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-Shot DSC-P92...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
