Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Dishes not getting clean. does the soap dispence supposed to open completly during the normal wash cycle
  • Anonymous Jan 22, 2009
    soap dispenser no longer opens properly during wash. sometimes soap doesn't get dispersed properly
  • Gardocki139 Jan 25, 2009
    after the cycle is done the soap dispenser is closed and fuel of soap, the dishes are dirty
  • 31 Answers
Yes.
Posted on Jan 20, 2009
I have a scum buildup in my Bosch dishwasher. How do I get rid of it?
Posted on Jan 28, 2009
The dishwasher completed it cycle but didn't use any dish soap and didn't clean the dishes.
It appears that, the soap compartment box did not open during the wash cycle. First check that whether this is the problem. If water flow is good and you are convinced that, the wash has taken place without the soap then, check the soap box relay latch ( if you can do it yourself.)
If this is not possible you have take the help of the service provider authorized by the co.
You can keep soap in a small cup and place it in the upper tray in a suitable place and run the wash till the repairs are attended!.
Oct 05, 2010 | Maytag Dishwashers
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Does the soap dispenser open automatically during the wash cycle, ours doesn't open and the dishes aren't getting clean.
does the cycle complete?. if it does and your dispensor is not open, then your dispensor is faulty. try opening it by hand, remove old powder, refill with 2 tablespoons of powder,select fast programme and see how you go. if your cycle is not completing then let us know what it is doing instead.
Apr 07, 2010 | Whirlpool Dishwashers
Dishes not coming clean, film ring on glasses and dried grime on the utinsels. Have run through twice with vinegar, not sure what to try next. Checked basket/drain and it was not blocked just has a small...
That sounds more like a problem with your soap not disolving completly. Try these few simple things. First, run your hot tap at your sink until it gets hot, then start your dishwasher. What this will do is ensure that your "prewash" is using hot water.
The next thing, is you want to select the "heated wash" or "hi temp wash" option with a "normal wash" cycle. What the heated wash will do is ensure that during the main wash the water gets boosted to 140 degrees wich is the temperature that your soap breaks down at.
White film left on dishes is a classic indication that the soap has not disolved or broken down completly.
Oct 02, 2009 | Bosch Dishwashers
Soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Apr 20, 2009 | Maytag DWU9962 Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Soap door doesn't open
remove the door panel and replace the wax motor on the dispencer
May 22, 2008 | Whirlpool 24 in. DP840D Free-standing...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
