Question about Brother HL 1440 Laser Printer
I have a Brother HL1440 and just changed the toner. Now it prints with three very wide black line with a thin white line in the middle (where there isn't any ink). It might be something that rolls in the paper? HELP!
    Novelist:
  • 170 Answers
Since you just changed the toner, more then likely it's going to be a defective toner. To test this you can either reinstall the old toner and try that and the lines should go away. If you don't have another toner to try, pull that toner out and open the shutter that exposes a metalic looking roller, If this is nice and clean then it's good and more then likely it will be a fuser issue but if you can see the lines on the drum then you know it's defective and you should be able to get a replacement from where ever you bought it... Hope this helps out, please mark it a fixya if this helped...
Posted on Jan 20, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
Brother MFC 8500 print issue
Hi-
Try cleaning the glass part with a glass cleaner solution with a damp cloth, but if you need instruction how to clean the inside part of it, suggesting you consult a technician or certified servicer for the product to avoid further issue. thanks for using Fixya!
Jul 16, 2008 | Brother MFC-8500 All-In-One Laser Printer
Bad toner cartridge? Wide white line down center of print
If you have a Brother color mfc, it sure sounds like a defective cartridge.
Brother machines do not perform well with generic or rebuilt cartridges and really have problems when you mix generic with Brother toners. It also voids any remaining warranty. Send it back. Good Luck.
Aug 07, 2012 | Office Equipment & Supplies
We have a Brother 4100 Fax Machine. When we send a fax or make a copy, there is a black bar about 2" wide that shows up the length of the page. It does not appear on incoming faxes. I believe it is...
Make sure the **** glass is clean, use a micro fiber cloth to wipe the debris/old toner or white out off the glass. restart the fax machine. If it prints this black line from a copy and it is 2" wide after you have cleaned both the glass and the white reference bar, most likley the scanner itself has failed.
www.brother.ca for further assistance.
Jan 14, 2011 | Brother IntelliFAX 4100 Laser Fax
I have a 525DN Brother Printer which has started printing a line in the middle of the papers and dumping ink out of the left side of the cartridge - do you know what may be wrong?
Thin line? Print a diagnostic page (3 pushes on the go button) and try changing the toner cartridge or drum, depending of the page says.
Nov 30, 2010 | Brother HL 5250DN Laser Printer
A black line is printed down the middle of pafe
The problem may be from either from the toner cartridge or the settings of the printer. change the toner first and see whether he problem still persist and also make sure that the settings of the printer on your system is ok, if the problem still persist after doing all this then it implies that you need to service your printer.
Sep 25, 2009 | HP Office Equipment & Supplies
Black smudging on all the page from hl1440-brother
  • Turn off the printer.
  • Take the toner off.
  • Shake the toner for 4-5 times.
  • Install it back.
  • Then try to print.
Thanks, CF
Jun 17, 2009 | Brother HL 1440 Laser Printer
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Vertical black line on all print outs
1) Check the cartridge. Look at the egg color drum and see if there is any built up toner. If there is then wipe off with soft cloth and reinstall.
2) Does this happen when coping from the flat bed and the doc feeder at the top?
If it it's only from the top then there is a glass lense that might have white out on it.
This is common when using white out and not letting it dry long enough.
To get to the lense it my be tricky but if the top of the feeder open a little from the top pop it open and
the glass is a thin 1/4 strip. Wipe it clean then try again. Hope this helps. Boats
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother HL 1440 Laser Printer Logo
171 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
