Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Wireless won't connect anymore
I have had my wireless for a couple years.  It has always worked fine.  Six months ago,  my connection has worked (stayed connected) less and less and now is at the point I can't connect at all. I could call Geek Squad, but they will charge 169.00 and if it is the box, I'd rather get a new one instead of having them come out to tell me that. It can't be cable because I am able to send this when I disconnect and put the connection directly into the computer.  Please let me know if you can help me.
Thanks, Reynee
  • Anonymous Jan 30, 2009
    I have the same exact problem. I disconnected the power for a couple of days now and reconnected it but the light on the power blinks then turns off. I tried resetting the router via the reset button as well. No luck. Any help would be appreciated.
    Scholar:
  • 141 Answers
Geek squad is expensive. Have you called linksys techsupport? Here is another option, try http://technicalsupport.blog.friendster.com
Posted on Feb 15, 2009
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have a wireless Linksys WRT1210N router. This is the third one in three years. In each of the last three years they all seemed to work fine for about six months before dropping wireless connections. I...
If you're connecting to the router via wireless, try preventing windows from controlling the power of the wireless card on your computer.
Device manager > network adapters > "double-click your wireless adapter" > power management
then uncheck the "Allow the computer to turn off this device to save power" option
I hope this helps
Jun 06, 2011 | Linksys WRT120N Router
Bought router in 2009 and worked fine up until about a month ago. Every couple of minutes will disconnect. Wireless connect on laptop shows it is connected. I get page not found. Soon as I unplug it...
try updating the firmware to the latest version.
http://en-us-support.belkin.com/app/answers/detail/a_id/306/~/f5d8236-4-n-wireless-router---firmware
it may fix any bugs or wireless issues in the update.
Apr 05, 2011 | Belkin F5D8236-4 Router
I have had my fujitsu siemens for nearly 4 years. When I first go it I had huge problems connecting wirelessly. BT did however seem to sort the problem. It was fine for 2 years, but again I'm having to use...
Yes if it's just Bluetooth you're trying to get to work by a new BT dongle. If wireless and BT are on the same card buy a new BT/wireless card This one Desktop 802 11ac Wifi Bluetooth 4 0 Dual band 1300M Wireless AC PCI... Works great. Try to stay away from Intel I had to replace two of them in the last six months. The link above uses Broadcom and works fantastic.
Jun 28, 2017 | Fujitsu Siemens Computers & Internet
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
Belkin Wireless Router will not go wireless.
go to your configuration site and make sure you have the SSID broadcast option on
Jun 22, 2009 | Belkin (F5D8231-4) Wireless Router...
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
Cannot connect anymore
Does the router work with the wired port connection? It's entirely possible that the router just went belly-up on you ...Linksys is an awesome brand, but sometimes it happens.
If the wired part works, the wireless transmitter inside may have gone bad. Best to just get a new one for about $50 ...but keep the old one in case you need a wired connection somewhere else around the house :)
Sep 28, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
138 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
