Question about Kohler - Toilet Seat - Moondance - K4717-CP-D8
How do you replace the seat on a kohler lowboy?
  • 80 Answers
There are two bolts that are under cover at the back of the seat. feel underneath for the nuts-pop the caps on top w/ a screwdriver. make sure you purchase the correct profile seat Elongated or standard..
Posted on Jan 20, 2009
Why does my kohler quiet seat not soft close anymore
The cams are worn out inside of seat or it may be to lose you have to tighten up the seat if there is any adjustments if not it is worn out replace toilet seat.
Jul 01, 2014 | Kohler K-4748-47 Almond Saile Quiet Close...
Where can I purchase a new Kohler 85330-cp-17 Teal replacement molded wood elongated toilet seat for our existing toilet?
You cannot. As you state, it is discontinued, confirmed on Kohler site.
If color is really important, consider painting it or a new replacement using an appliance epoxy spray paint such as Rust-Oleum after careful preparation of the surfaces.
Jun 13, 2014 | 85330-BR-17 Part - Teal Assembly Seat-...
Eljer one-piece lowboy toilet - toilet seat cover screws could not be removed
You may have to use a really neat tool and that is aunt splitter. You can get it at O Reilly's auto store or any of those stores. That should remove it.
Feb 05, 2013 | American Standard Home
Converse lowboy battery
Recommend you don't. Let a watchmaker do it/
Oct 14, 2012 | Converse Lowboy Thin Digital Watch - VR005...
I tried to unscrew a toilet seat on a lowboy now the screws won't screw or unscrew.
If the screws won't turn either way, they're probably "cross-threaded" or stripped. You'll have to unscrew them with force. I'd use a ratchet and socket on an extension (you might want to use a deep socket, since the bolts often extend an inch or two past the nut).
Once you get them off & can remove the seat, head to the hardware store or Home Depot & pick up a new set of bolts & nuts. They're very inexpensive. When installing them, make sure that the nuts screw onto the bolts with finger pressure alone, before taking a wrench or pliers to them.
If using force to unscrew them ends up damaging the toilet lid/seat assembly (this is the worst-case scenario), then you'll have to spring for a new toilet seat. The up-side of this is that new seat/lid assembly come with the screws and nuts, and - depending on what you want - can cost as little as $15 for an "economy" model, and up to $30-35 or so for a "deluxe" model.
Mar 03, 2011 | Kohler - Toilet Seat - Moondance -...
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
I HAVE A LOWBOY KOHLER TOILET AND I CAN'T FIGURE OUT HOW TO CHANGE THE SEAT. THERE SEEM TO BE NO NUTS! PLEASE HELP.
They might be expanding fasteners that only need access from the top. Did you pop off the caps on top and loosen the screws with a screwdriver?
Jan 18, 2010 | Kohler - Toilet Seat - Moondance -...
Kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Jul 29, 2009 | Kohler - Toilet Seat - Moondance -...
Kohler - Toilet Seat - Moondance - K4717-CP-D8 Logo
656 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
