Question about Intel D845WN (KD845WNPAK10) Motherboard
Memory upgrade problem
I attached a hynix 256MB SD ram of 133 bus,the pc worked fine some day but now it's making a huge problem.after detaching the ram from PC, it's working fine.Now which type of memory is well for my motherboard?The PC restarts continuously when this ram is connected. Pls Help Me. Thanks.
    Genius:
  • 2,985 Answers
Go to www.crucial.com Here you will find a free program to download that analyzes your Motherboard and will tell exactly what memory it needs - you can then order this online from Crucial.
Posted on Jun 28, 2007
Problems with memory upgrade to vostro 220 mt...2gb hynix wont work on its own ...got a piece 2gb hypertec wont work on its own either...why is it so finicky? going back to 1gb hynix which came with it all...
RAMs are not compatible...
if u have MSoffice 2007, there is tood there in that u can use that to check the RAMs comaptibility...go to
Start/All Programs/MS Office 2007/MS office Tools/MS office Diagnostics
Else u can downlaod a RAM checker from google
Dec 24, 2009 | Dell VOSTRO 220MT E8400/3.0G 2G WVB 160GB...
Hi, Replacing my 256mb ram (1 slot) with 1Gb (2x512). The computer would not boot. Removing 1x512 memory the computer works fine. I put my old 256Mb back with the 512 Mb and the system only reported 256Mb....
Is the speed of the RAM the same mixing PC 133 and PC100 ram can cause problems working together. Also it sounds as if your board will only upgrade to a maximum of 512 MB total.
Aug 15, 2009 | AOpen Computers & Internet
How do I upgrade memory on a t1100 emachine from 256mb
Your emachines eMachines T1100 only supports modules made with a specific type of chip. Should you find what seems to be the exact same memory elsewhere for a lower price, it is very possible that the cheaper memory will not work in your computer. From what I see you should use straight PC-133 Try a site like Kahlon.com-they make sure it works with your computer as would kingston or corsair...
Your maximum amount of ram is only 256mb total.
hope this helps...good luck- please leave a rating...thank you kindly
Apr 26, 2009 | E-Machines T1100 PC Desktop
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Ram upgrade problem
Are ou adding them along with the 256MB memory? That could be the problem
Mar 09, 2009 | Dell Dimension 2400 PC Desktop
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Well i have a compaq presario 1700 XL360 it came with pc100 64 memory ram i tried to upgraded with two 256 memory ram to bring it to total 512 mb thats the max for this computer ...
There is a good chance that your system needs a firmware upgrade in order to recognize the bigger memory. I found one in this page
Be carefull and follow the instructions since you could brick your system.
If that does not work, do not expend more money in that system (very old), just save to get a new one.
P.S. The memory you got is the right kind.
Good luck
Dec 12, 2008 | Compaq Presario 1700 Notebook
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Intel D845WN (KD845WNPAK10) Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
