Question about Boating
I have a boat motor that will hit high rpm's in neutral , but when you put it in gear the boat will only reach about 5 miles an hour
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Sounds like low compression. You can check with gauge at plug holes. If you dont have one , you can get a loaner at auto parts store.
Posted on Jan 12, 2013
4 Suggested Answers
  • 75 Answers
SOURCE: Prop not turning
if the prop spins out of the water but not in
it could just be a bad hub inside the prop
good luck with it
Posted on Jul 06, 2009
oldfishead
  • 155 Answers
SOURCE: Shifter jumps out of forward gear on 64 9 1/2 hp Johnson motor
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
  • 5 Answers
SOURCE: My mercury 135 boat motor cuts off when I put it
hmm!!!!!!!! just cut off ah gear.
Posted on Apr 03, 2010
I have a 99 chevy malibu with roughlt 220 thousand miles... make a long story short I was in a fender bender at about 25 mph. Minor. Impact front left panel. Completely drivable from the scene. Well I only...
Sounds like maybe a motor mount may have broken,if you
open the hood and put the car in drive ,then neutral then reverse
the engine should only "rock" about an inch or so,if it really jumps
that is the problem.
Feb 26, 2013 | Cars & Trucks
When in 6th gear auto pops out into neutral on 2001 360
Are the bonnet and boot close switches making properly? I found with mine that they are not then it goes straight back to neutral as it does not want you to drive with either open. Also it could need the ecu reprogramming as it might've 'forgotten' what it's doing.
Oct 16, 2012 | Transmission & Drivetrain for Ferrari 360
Rpm are way high. at 60 miles an hour the overdrive kicks in, rpm shoot up to 4000
Either the torque converter isn't staying locked-up
or your in third gear,not od, as you suggest.
In OD, which is fourth gear, rpm goes down, not up
So you know you have to go to a trans shop
Drive it like that one more day & you will ruin it,
as I suspect may have happened already
Aug 03, 2012 | 1994 Cadillac Eldorado
After fixing waterpump & new prop, wouldn't rev right out in gear, screams in neutral.
what type of engine and what size prop? sounds like the shifting rod isnt in correctly. Depending on what type of motor it is if you moved the shifter while removing lower unit and did not get shifting rod in same position as control box lever it is stuck still in the position
Mar 21, 2012 | Boating
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
My 2003 Ford Expidition XL is stuck in 1st. gear
to take out of low range start vehicle put it in neutral gear hit the 2 wheel high button or if its a shifter on the floor put in correct gear. within seconds light should go off
Nov 21, 2011 | Cars & Trucks
My R1 works fine but after 5 minutes of running it the RPM goes high if the bike is on neutral and i have to change the gear with the higher RPM and once i put it in 1st or 2nd gear and release the clutch...
Try adjusting your idle speed screw in neutral.
Check your throttle cable to make sure it's not being pulled while turning the forks.
Check your choke cable and make sure it's adjusted properly.
Apr 02, 2010 | 2000 Yamaha YZF-R1
2003 yamaha 4 stroke will not rev when put in gear,at full throttle motor remaims at idle rpm
there are two sets of cables coming from your control box. Onne of the cables switches you from foward/neutral/reverse, and the other cable is for the throttle. either you've have some linkage come loose on your throttle cable, of the cable has broken inside the plastic tube it's housed in.
Jun 22, 2009 | Boating
Problems wont pass 4000 rpm's
Depending on the model of accord. It may be a VTEC malfunction in the computer. If it's an EX it is a VTEC
Jun 16, 2009 | 1999 Honda Accord
Boat motor help
i need a little more info like what kind of motor is it?
Sep 01, 2008 | 2001 Chevrolet Impala
Boating Logo
64 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
