Question about Midland Radio Cameras
My xtc 100 wont turn on
It wont turn on ive put in new batteries and it still wont it worked the first 3 times i used it ice fishing and it worked with green battery life and today it switched to red it wasnt even flashing red and it turn it on while im catching fish to get a good video and it turned on and after i cought the fish i tried to turn it off and i had the switch off but the lights were all on except for battery and i brought it home and took the batteries out and put them back in and now nothing will turn on. please help
    Top Expert:
  • Midland Radio Master
  • 79,851 Answers
There is nothing you as the end user can do to fix this camera. The reason they do not sell parts or repair information to the public. Either replace it or send it in to the manufacturer for exchange.
Posted on May 17, 2017
Worked fine put new battery in changed nothing wont work just clicks at relay box
The new battery was charged before you put it in? Or you just assumed it was charged?
When was the last time everything ran fine? yesterday, or half a year ago? because in a long period, lots of things could have corroded or just got defect.
Mar 14, 2015 | Boating
My 40" Soniq tv wont turn on?it was working this morn.I switch it of abouut 5 hours ago and ive tryed turning it on for about an hour?Ive unplugged tv from power board for 10 mins,plugged it back in and it...
Are you tech savvy?...I can give you some voltages to test if you're able to do that, if you aren't then you have 2 choices, take it somewhere to be serviced but expect to pay between 75 and 100 dollars an hr for tech time plus parts or replace the set with a new one.
Feb 11, 2018 | Televison & Video
XTC-200 Midland camera not charging
Check the charger. And not every USB outlet can supply enough power to charge batteries. Then check the cable and the connectors, on both the charger and the camera. Something must stop the current to flow.
Jul 15, 2014 | Midland Radio Midland Xtc-200 Ultra Small...
HELP!! my nokia 6500s wont allow me to get on the menu screen,, whenever it starts up,, it shows Push to talk,, and it wont go away,, ive restarted it several times,, it still shows push to talk,, push to...
Try doing this. Turn off the unit, remove the battery, press and hold the power button (while battery is out), then put the battery back and turn it back on. If that doesn't work, just repeat the steps including removing the Sim Card. Or turn on the unit without a Sim Card.
You can also try using reset codes but that would reset EveryThing back to default settings which might include losing the settings of your provider which is not recommended. But the initial step is safe to use.
Hope this helps.
Nov 16, 2010 | Nokia 6500 Slide Cellular Phone
My virgin mobile xtc has a white screen what can i
just take out the battery and put it back in (do not put the cover back on) then let it turn white then wait like 10 seconds then push end 2 or three times (to make sure anything that may pop up when you regularly turn on your phone is gone) then hold the end button (as if you were turning your phone off) then let go of the off button then pull the keyboard out then use ur hands to press the battery in tight (the battery should already be in the phone at this time but just press down like you really want the battery to be in place)
Dec 25, 2009 | Kyocera wild card Cellular Phone
Evinrude 9.9 starts but when i turn it off it wont restart
With what you say,I had a very similar problem.This may not be the same as yours but what I did was a new set of sparkplugs.It worked.For the price,for the ease of doing it,it was a cheap fix.This may not be a 100% fix for yours but if it does help you,great.My motor used to go through sparkplugs a lot.It was never solved.Hope this helps
Sep 07, 2009 | Shimano Citica 200E/Cabela's Fish Eagle II...
Phone wont start up
huh i have the same phone mabye u droped it try a new charger or new battry
Jun 25, 2009 | Sharp 903 SH Cellular Phone
My samsung juke wont turn on. ive charged it several times and still nothing. ive sent it to electronic experts and nada. ive taken th battery in and out and nothing. Ive held the END button on the phone...
Does the Verizon logo flash when you plug it in? I had this same problem. Take the battery off. Plug the phone in. Observe the flashing logo. Put the battery back in. Observe "Charging..." screen. Power on. Unplug. Good to go.
Jun 05, 2009 | Verizon Communications Samsung Juke Cell...
04 yfz 450 wont start with electrical start
i have a 04 yfz 450 quad. the compression ratio like yours is extremely high. ive had my battery go bad and found that another battery other than factory would turn over the engine, but would not start. i paid the 100 dollars for the factory battery and it fired right up. because of the high compression you need a high cranking battery.
May 04, 2009 | 2004 Yamaha YZ 450 F
My N70 Won't Turn On At All
petrosp your n70 needs to be flashed with new firmware. In the worst case some hardware got damaged
Aug 11, 2008 | Nokia N70 Cellular Phone
Cameras Logo
Top Midland Radio Cameras Experts
Are you a Midland Radio Camera Expert? Answer questions, earn points and help others
