Question about Samsung R530 Notebook
Samsung r530 bad sector hard drive. Did not come with operating software disc.
I get boot noises and cannot boot messages. Someone told me the reader arm may be going. I did a Samsung recovery backup. message said I had a bad sector. The laptop did not come with a OS disc. If I replace the hard drive how do I add the OS?
  • Samsung Master
  • 7,627 Answers
Remove the HDD and test, replace if necessary. You can contact Samsung, with your laptop Serial Number, and purchase a Factory Recovery DVD. Or, you can buy a Windows Installation DVD and do a Fresh install on the new HDD.
Posted on Jan 06, 2013
flipbooks
  • 177 Answers
SOURCE: Samsung N120 Netbook won't start Windows. stuck on black screen.
See if you can download it from Microsoft. It seems to be related to the languge translators in Windows (NLS file).
Posted on Jul 31, 2009
  • 53 Answers
SOURCE: Can I get a recovery disc for a Samsung N130?
if have a licence, reload the laptop and drivers are easy to get. samsung **** for support. most likey xp home or pro oem. you can use anyones xp disc as long as it matches your licence.
if you dont have alot to spend when loaded try open office save money buying office or pirated software and avira for protection the free version is rarther good,and malewarebytes for male ware.
just a few ideas!
Posted on Feb 11, 2010
Testimonial: "Thanks very much for a very speedy response, giving helpful suggestions as well as an answer"
furiacega
  • 548 Answers
SOURCE: my samsung r530 wont read
Unscrew the screws that hold the hard drive, unplug the device, clean the header with some medicinal alcohol. Also clean the motherboard header(where the HDD is connected) in the same manner. Leave it for a couple of minutes to dry, then plug it again.
If it is not working try to test with a different hard drive. If it is working than your hard drive is broken.
If you need further assistance, or have further questions, just leave a comment. Thank you for using FixYa. Cheers
Posted on Jan 20, 2011
  • 115 Answers
SOURCE: my brother's samsung r530 wont boot up as it is
That is most likely the BIOS password, the best solution would be to ask your brother for the password so that you can boot to Windows and use it.
Posted on Mar 02, 2011
  • 3278 Answers
SOURCE: status: 0xc00000e9. samsung R530 will
Hello, Tracy.
You may have a hardware error - hard disk may be going bad.
Run your computer's diagnostics by pressing continually pressing F12 (it's possible for your system that another function key loads the diagnostics) upon boot and choose diagnostics. Let it run but pay particular attention to the hard drive diagnostic. If you get an error, your hard drive is probably going bad and would need to be replaced.
If not a hardware error, it's possible that there is a system file problem. Boot your system again, but this time press F8 to access System Restore. Choose a date when your system worked OK and follow the process.
Hope this helps.
Posted on Jun 23, 2011
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
Dec 02, 2014 | Samsung R530 Notebook
Samsung r530 wont boot up
Unfortunately, in my past experience this particular model it seems to have a very bad habit of hard drive failure on a regular basis. The particular samsung hard drives used in it are horrible and so is samsung support. You don't say weather or not you can boot from the CD/DVD drive with a live cd in it, but you should try getting one and trying it out.
Get a copy of Hiren's boot cd from here:
http://www.hirensbootcd.org/files/Hirens.BootCD.15.1.zip
Extract the iso and burn it to a CD, then put the CD in your CD/DVD drive and boot from it. Use some of the Hard Drive 'diagnostics on the CD to determine if the Hard Drive is Dead Like I think it probably is. Then Contact Samsung support from this page:
http://www.samsung.com/us/support/owners/product/NP-R530-JA02US
Keep after them until they address the problem to your satisfaction. This is a VERY common problem with this particular model so give them an earful!
Jul 28, 2012 | Samsung R530 (NPR530JA02US) PC Notebook
My samsung Q45 notebook tells me to insert the windows installation disc and restart my computer. I have not got this, can anyone help?
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
Jul 09, 2012 | Samsung Q45 Notebook
Disconnecting when copying large files (about 1gb and above)
that means it there are bad sectors on the hard drive. search for Hirens utility boot disk with google and and download the software. After you downloaded it you will have to write the files to a cd. Then boot up with the disc and select Hard drive tools or HDD tools, then select hard drive re-generator to detect and repair bad sectors if there are over 500 bad sectors then replace the drive.
Feb 25, 2011 | Toshiba MK1234GAX 120 GB ATA-100 Hard...
Having dropped my Samsung R530 (nothing obviously broken), when I try to stsrt it it is coming up with the message:- "Boot From AHCI CD ROM: Operating System not found" Any ideas?
Hi tony prother,
"Boot From AHCI CD ROM: Operating System not found" error is because the system is booting the CDROM of the system and its not detecting an installed Operating System. You need to check if the system still detects the Hard Drive of your laptop on the Bios page. To go to BIOS reboot the computer and tap F2 on the system and on the bios page check if the hard drive is detected then go to then BOOT Tab select the hard drive as the first boot priority and reboot the system.
If the hard drive is not detected it might be damage, you can get intouch to a local tech to check and backup the files.
Thanks for using Fixya.
Jan 28, 2011 | Samsung R530 (NPR530JA02US) PC Notebook
My samsung r530 wont read its hard drive. how can i fix this problem?
Jan 20, 2011 | Samsung R530 Notebook
My toshiba satellite A215-S5837 when trying to bootup gives error message cannot boot do you want to start from last good boot. I say yes it still does not boot just goes so far and then I get clicking...
once you get a bad sector it usually spreads like a virus through your hard drive. the best thing to do is to buy a new hard drive, install it and do a clean install of windows. you can buy or borrow a hard drive enclosure and rescue your documents from your old drive but isolating the bad sector doesn't work, especially if your drive is making a noise
Jan 13, 2011 | Toshiba Satellite A215-S5837 Notebook
My operating system is corrupted by a virus i tried to slave my hard drive but i can only see my hard drive in bios and i cannot see it in my local disk drive and im hearing clicking sound inside my hard...
Try to boot from your OS cd or recovery disc. Run the disk check software and see if your hard disk is mechanically ok or it crashed. If your hard disk is mechanically functional then run virus check on your hard disk. This will clean all the virus infections. And you will be alright hopefully.
If your hard disk's boot sector is damaged you may want to format the hard disk and place the boot sector in another portion of hard drive.
Nov 07, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Samsung R530 Notebook Logo
183 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
