Question about Husqvarna Chain Saw 20" Bar
Sucking air my 41 acts like it is giting no fuel when i giv it gas
My 350 does not **** up any fuel?
Posted on Jan 26, 2009
    Problem Solver:
  • 16 Answers
First check the fuel line.If not clogged, then check fuel bowel,the needle and float may be clogged or stuck .remove carb.and give it a good cleaning.An air gun and can of carbcleaner works wonders.
Posted on Jan 21, 2009
1999 3 cyl. Johnson will not stay running. Has new gas new line from tank
It could be starving if fuel. Increase power, increase demand. Ensure no trash got left or sucked up into the fuel lines during the replacement process. Also ensure you don't have a leak somewhere, either positive or negative. An engine that got a gulp of air in the fuel line can act the same way.
Apr 28, 2017 | Cars & Trucks
My 2005 grand caravan is acting like it's not getting any gas has 3/4 of a tank in it any ideas on where to start?
Fuel filter, fuel pump, rubber portions of the fuel lines allow air to be sucked in. Run a diagnostic test to see if any other codes come up indicating other factors which may causing the problem.
Dec 21, 2015 | Cars & Trucks
2001 Polaris Trail Boss 325 replaced float in carberator, runs fine with air filter cover off not so good with air filter cover on can you help
You are choking out for some reason. Fuel too rich.
1) I assume you change to a new air filter
2) go to premium gas. Old gas basically acts rich, even if the float and needle valves are set correct.. Drain the old and use only high test from here on out. Also use seafoam in the gas or STP treatment to protect the gas.
3) adjust the fuel mixture to make the slightly leaner.
4) look for any type of leak in the throttle body or other vacuum/breather tube. Air is sucked in under vacuum and the back pressure of the air box is not being overcome. Good luck!
Jan 26, 2015 | Garden
How to adjust air-fuel mixture on GHAEA 3183259?
FIRST change the air cleaner filter. Clogged filter acts like the choke is on and it sucks more gas then Air.
Aug 18, 2014 | Garden
Fuel filter location
Loosen has cap if sucks air, check Evac system. Try driving with cap loose. Also check tale pipe by putting hand over it, no air out means no air in.
Oct 05, 2017 | Nissan 200SX Cars & Trucks
I have a 2009 ford e-150 cargo van , keep getting codes P0150 & P2195 what do the codes stand for
02 Sensor Circuit Malfunction (Bank 2 Sensor 1)P2195 - O2 Sensor Stuck Lean (Bank1 Sensor1)
Jan 04, 2012 | Cars & Trucks
2001 ford f150 supercrew. sounds like the fuel pump is sucking air. im not getting any gas what so ever to motor. it acts like it want to start sometime but not to offten. it will start up if i spray...
do not use starting fluid. pull the line off from the fuel filter (line comming from the tank). put the line in a bucket and have someone turn the key a few times. if there is good flow replace the fuel filter, if not replace the fuel pump
Oct 10, 2011 | 2001 Ford F150 Styleside SuperCrew
Ran out of gas in my 02 1500hd
It sounds like your fuel filter is clogged. This often happens after you run out of gas because your engine sucks up all the gas in the bottom of the tank where dirt and debris have been collecting for years. I recommend changing your fuel filter and if that doesn't fix your problem, add some fuel injector cleaner to your gas.
Jun 09, 2009 | 2002 Chevrolet Silverado 1500HD
Husqvarna Chain Saw 20" Bar Logo
79 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
