Question about BenQ W710ST 3D HD Short Throw DLP Projector
I have a Benq w710st DLP projector and when i turn the power on after a minute it turns off. The power button turns off and both the lamp and temp lights turn red. How do I fix this and can I do it my
Bought it used. First time i turned it on it started turning off after one minute. I also noticed on the menu under lamp hours it said zero. Do I need a new bulb too?
  • BenQ Master
  • 3,904 Answers
New bulb is probalbly needed. You need to find out what zero means on that projector. The real problem is finding out why the cooling fan is not turning on. This is probably the reason that the temp light is coming on.
Posted on Jan 07, 2013
4 Suggested Answers
SOURCE: My Benq PB6100 shut off after a few seconds
I had the same problem.
First thing to do is look up the owners manual, unless you happen to still have it, then verify the the sensor for the second (or rear something that sounds not like first) temp sensor is going off. If it is basically the fan that sends air into the lamps compartment may be clogged. I have had mine for several years and recently had the same problem. I almost went out to buy something new until I convinced myself that there was no harm in taking it apart and trying something. Good thing too, since all I had to do was clean the fan and reassemble. After that it stopped turning off by itself and I haven't seen any red lights.
Good luck to You!
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
  • 11800 Answers
SOURCE: I have a BenQ PB6100
The inverter - the system that generates the high voltage needed by the bulb - has failed due to normal wear. When that happened it has surely done some damage in the power source also.
The projector is fixable, the inverter/ballast board will have to be replaced and the power source tested and repaired if necessary. But on an such old device, age related failures will be common from now on and in the end fixing them will cost you more than a new one - it's time to accept that this one has done its duty and it's time to retire.
Just cut your losses and buy a new one.
Posted on Jan 07, 2011
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
BenQ
Check the bulb and/or bulb fan for proper operation.
Aug 03, 2017 | BenQ MP523 DLP Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
BENQ mp720 stops after 20 minutes and needs to
clean out the dust with canned air and make sure the fans work. if the lamp and power board can't cool down, it shuts down to prevent damage.
Sep 22, 2009 | BenQ MP720 DLP Projector
BenQ W710ST 3D HD Short Throw DLP Projector Logo
494 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
