Question about Remote Start System
My avital 4103 will not lock or unlock my doors on my 01 crown vic
I have tried adjusting the pulse duration but none seem to work. I know it is hooked up to the correct wires, and i hear the unit click when i press the lock/unlock button but nothing happens.
  • Blake Bruce Jan 06, 2013
    It is an Avital model 4103, 2001 crown victoria p71, I am a technician, but not at a certified DEI corporation. The car does not have a factory keyless entry system, but it does have power locks. Also, on the OEM wiring I see a "Lock Motor Wire" but I do not see anywhere to connect it to the remote start.
  • 139 Answers
It sounds like you wired up the door locks incorrectly. You need relays to control your doorlocks. Follow the diagram in this link to wire up the relays.
http://www.the12volt.com/doorlocks/page3.asp#5w
Posted on Jan 09, 2013
3 Suggested Answers
  • 13 Answers
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Posted on Dec 04, 2008
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
I have an avital 4103 in my 2004 silverado. It won't unlock the doors and it starts but immediately quits.
There is a bypass module that communicates with the truck. It's in addition to the 4103 system. It's lost its programming or is disconnected. Sometimes you can unplug the module, turn the key on, plug module back in, turn key off, then on and start. All should be working fine again.
Jan 14, 2014 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I need to know the steps ( opening driver door, turnig the key on n' off etc,etc. ) to activated the alarm 4103
The 4103 is not an alarm! It's a keyless entry and remote starter. So...what are you trying to do.
Feb 13, 2013 | 4103LX Remote Start System with Two...
Doorlock operation won't work on new Avital 4103. Why? 1990Buick LeSabre
The door locks on the car are reverse polarity so u have to put realys in between the system and the door lock
Oct 21, 2012 | 4103LX 4Button Remote Start System with...
How do I get the horn to honk on lock/unlock? Avital 4103 model
this requires a connection from the H1 harness to the vehicle horn wire. in some cases a relay may be necessary as well. additionally the feature needs to be turned on in the programming menu.
Mar 26, 2011 | 831002/4100 4100 REMOTE START SYSTEM WITH...
On my 2000 ford crown vic. the power door locks work except for the drivers side. sounds like something is rattleing in the door. any ideas on what and how to fix
the power lock in that door may have broke the rod. remove the door panel to inspect its operation and replace the necessary part. hope this helps
Jan 31, 2011 | 2000 Ford Crown Victoria
Hi i have a avital key fob 474l that stop working two days ago it will not unlock or lock the doors.
hi have you checked the battery or more so replace the battery and try it seems to be the only solution i know same problem happened to me and yes it was the battery goodluck
Jan 30, 2011 | 474L Avital 4Button Transmitter 434 MHz...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
My avital 4103 does not unlock the passenger door when unlocking OR set the alarm when locking - should it?
Its not the avital piece that's the problem, it's your INSTALLER that is/was the problem....haha, got somethin wired wrong!! It only does what you install it to do! :)
Dec 11, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Remote Start System  Logo
273 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
