Question about Samsung Pn60e7000 60 Inch 1080p 3d Wifi Plasma Hdtv
Removing a stand from a pn60e7000ffx2a
Stand on the tv will not come off
4 Suggested Answers
SOURCE: removing stand from tv
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Posted on Feb 09, 2008
jerryg50
  • 1667 Answers
SOURCE: TV Stand
Start at the link below. Select your country, and then look for customer service, or support. They will tell you who their dealer is in your area for Sanyo parts and service. You will be guaranteed to have the proper parts.
http://us.sanyo.com/home.cfm
Jerry G.
Posted on May 06, 2008
SOURCE: removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Posted on Jan 08, 2009
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Removing the tv stand from tv
There are 4 screws on the back of the tv 2 on each side of the plug remove these and the stand will slide right off.
Mar 22, 2009 | Televison & Video
TV wobbles on its pedestal stand.
Sounds like stand has been installed wrong an maybe miss aligned, and screws may be loose! Try removing and start over, or call installer back.
Feb 28, 2009 | Televison & Video
Removing the stand from tv
I called Panasonic customer service and they directed me to their website where I was able to download that portion of the manual that addressed removing the stand.
Feb 03, 2009 | Polaroid TLA-01911C TV
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Nov 06, 2007 | Televison & Video
Samsung Pn60e7000 60 Inch 1080p 3d Wifi Plasma Hdtv Logo
22 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
