I have a dell Inspiron 1520, it's older, it says
  • 691 Answers
You haven't inadvertantly pressed the keyboard key that urns wireless off have you?
some older network cards are incompatible with the latest encryption so you could try setting the router up to use wep encryption 64bit instead
Posted on Jan 06, 2013
  • Brittany Johnson Jan 06, 2013
    I'm sorry but I'm very computer illiterate :/ as far as I can tell everything is in order, my laptop is just not allowing itself to find any available wireless networks. It has connected before so I'm not sure what the problem is now?
  • Daniel Bakewell Jan 08, 2013
    is the light on for wifi... second one up on the right near the delete key? if not turn it on by flicking the switch on the left side of the computer near the back. Try this website for further instructions or get back to us on here. :O) http://support.euro.dell.com/support/edo...
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Dell Laptop is not pulling IP address
Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then Before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then righr click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Posted on Feb 27, 2009
lorenzo_most
  • 60 Answers
SOURCE: Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Posted on Apr 02, 2009
Restore task bar to default position in xp
To reset your taskbar to the default position automatically in Windows XP and Windows Vista, click the Fix it button or link. Click Run in the File Download dialog box, and then follow the steps in the Fix it wizard.
Note this Fix it solution will close all open Windows Explorer windows when it runs.
Mar 26, 2013 | Dell Inspiron Computers & Internet
Can I increase my processor in a dell laptop 1520 xp so I can download windows 7?
no processor upgradation this model upgradation means change MB also this is not possible
Oct 24, 2012 | Intel D845GVSR Motherboard
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
The "galaxy of games card classics"will not run/play on my dell 1750 inspiron for some un known reason, can you fix this problem? '
You can run older programs in Windows 7. Here are 2 fixes:
1. Run a Program in Compatibility Mode in Windows 7. This one is easier, so try this one first. It should work.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
2. Run Windows XP Mode with Virtual PC. This one more complicated because it involves installs and running a virtual system. Use only if you feel comfortable with instructions.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Sep 25, 2012 | Dell Inspiron 1750 Notebook
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Dell Inspiron 1520 won't shut down when printer connected.
Try disabling the startup items or edit it. Go to Start -> Run. type msconfig. Choose Diagnostic Startup. Reboot.
Please rate this if this is helpful.
Dec 09, 2008 | Computers & Internet
Drivers Inspiron 1520
no problema.
ver a este site
support.dell.com
empuje el numero de model
y tambien la systema de opperaccion
sabes?
Oct 23, 2008 | Dell Computers & Internet
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
