L can't connect cd rom - Computers & Internet
  • Anonymous Jan 23, 2009
    it's internal drive. You can not find it on my computer nor when u click on the rom to open, it does not repsond.
  • Greg Lumpkin
    Greg Lumpkin May 11, 2010
    Can you be more specific? Internal or External drive?
    Problem Solver:
  • 11 Answers
Why
Posted on Feb 23, 2009
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
I want my desktop to boot from cd. But in the boot priorities there is no option for CD-ROM. How can I make CD-ROM first boot priority?
If there is no cd rom, you need to check for it your bios detects your cd rom drive, and make sure you connect it properly.
If you are using IDE CD-ROM,make sure it doesnt conflict on your Master-Slave configuration. if you are using SATA CD-ROM make sure it connects properly to your SATA Ports, and also check if you have properly connect the power cable to your CD Drive.
Jan 05, 2010 | Computers & Internet
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
CD ROM DOES NOT APPEARS ON MY DESKTOP. WHEN I OPENS MY COMPUTER THERE`S DOES NOT APPEARS THE CD-ROM`S ICON.
1.check your connections of CD Rom inside the Cpu box, if any loose contacts there, then your cd rom wont appears on the computer,
2. change the data cable
3. connect different power socket to the cd rom
4. goto Bios setup, press Del key or F2 key to enter the Bios setup
5. check your cd to detect
6. save it and restart your computer
Jun 22, 2009 | Intel D101GGC Motherboard
Need to instal cd/dvd rom into Dell lattitude laptop
You will need to connect to cables.1 is from the power supply and one is from motherboard.Just connect both to the ROM and start the computer.Windows will automatically install the drivers for your ROM..
Nov 09, 2008 | Dell (6T980-A01) CD-ROM Drive
Computer
Hi Diviola, you have no choice but to buy a CD-ROM drive. They are not as expensive as you might think. You're windows CD can format the hard drive in you're computer before installing windows. Some people can use a USB memory stick but in order to copy the windows CD software to the memory stick you'll still need a CD-ROM drive. A 2GB or 1GB memory stick will cost as much or more than a CD-ROM drive. Please click on the link to see some prices for a standard CD-ROM drive.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& here.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287198&CatId=87
The link above is a CD-ROM drive & can also make CD-RW's (RW stands for re-write).
You can replace you're CD-ROM drive you're self. Just do not disconnect the cables from you're old CD-ROM drive untill you have the new drive. Connect the cables to the new drive (one at a time) as you disconnect them from the old CD-ROM drive.
Double check that the cables are tightly connected before you power up the PC. Load you're windows CD into the new CD-ROM drive & when you start you're PC up windows will start to load.
When you receive the new CD-ROM drive & if you need help connecting & running anything. You can come back here & ask questions. I'll help you through this.
Luck!
Mike
May 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
CD ROM is not detect in My Computer
dtect your rom in bios
and try.
Apr 01, 2008 | Intel Motherboard
My cd-rom has trouble reading disks
1.some times this happened the loose connection of the IDE cable,and power cable.
2.so disconnect the IDE and power cables and then connect again.
if not fix
3. exchange the IDE cable of hard disc.
4.if no result,the lens of CD Rom has damaged, you will be have to buy a new CD rom....
thanks!
Mar 02, 2008 | Computers & Internet
Cd rom 52x mtrp
check the driver version for an updated one on the internet
Feb 03, 2007 | AOpen CD 952E Internal 52x CD-ROM Drive
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
