Question about Motorola Mobility RAZR V3
Blue screen on outside display screen
Hey, I have had my Razr phone for a while now...and it has definitely been put through some tough times. I have been noticing recently that the outside screen will go all blue and not show any of the regular displays. It usually will show the phone service logo, the time, and the date. When my screen goes all blue all that stuff disappears. I have tried powering it off and turning it back on and it will still do this. I even tried taking the battery out and putting it back and then re-powering....I still get the same thing. It does it at different times and I have been noticing it when I plug it into the charger. What is wrong with my phone?
    Brigadier General:
  • 7,752 Answers
You need to have the LCD replaced on the mobile.
Posted on Apr 15, 2008
2007 razr v3m can make calls but display screen
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
Mar 20, 2010 | Motorola Mobility RAZR V3m Cellular Phone
DISPLY
replaced the LCD on the phone.
Jun 27, 2008 | Motorola Mobility RAZR V3
Pink razr phone lcd front screen problem
you need to change the LCD so take it to a mobile service center and have them replace the lcd for you.
Mar 13, 2008 | Motorola Mobility RAZR V3
Outside screen is blue
have the lcd replaced on both phones.
Mar 08, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
http://themotoguide.com/razrdisassembly.php
hope this helps you out.
riz.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Outside screen
You need to take back up of your phone and master reset your phone. The problem will be solved.
Oct 22, 2007 | Motorola Mobility RAZR V3
Outside screen works inside does not
That's a problem with the dispaly of ur phone just go to service centre and let them check its a hardware problem. and at the dame time ask them to flash ur handset.
Oct 18, 2007 | Motorola Mobility RAZR V3
White screen on Motorola RAZR
I use to work for Cingular Wireless and this happened often. Try opening and closing the handset a little forcefully. It should re-seat the screen onto the contacts. If that doesnt help, have it replaced since its new. Best of Luck.
Sep 05, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Razr V3M's external display not showing wallpaper. iTunes help too!!??
As far as I know only razr v3i has i tunes. as far as the external display not showing your wallpaper as the internal screen i'm not sure except if it dosen't show the time and stuff on the external display your screen's connector for your display may be loose if so thier should be a solved problem for that.
Mar 12, 2007 | Motorola Mobility RAZR V3
Black Outside Screen
When you are looking at the RAZR, push the button on the right hand side. This should light up your outside screen to see the time when the screen is dark. Have you tried this?
Dec 23, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
