Question about Lindhaus Activa 30-38 Bagged Upright Vacuum
Getting the vacuum to start after replacing the bag
Whenever I replace the bag, the vacuum does not want to start. I cant understand, and its frustrates me to the limits. Is there some sort of reset button I need to push? or something I need to do? It takes me so long to get it to work, and once I do, I can remember what I did for the next time. Any help would be great.
  • 32 Answers
Behind the door and above where the bag is located there should be a piece of plastic, or metal that sticks out, at least in the manual, if the door isn't shut correctly, that piece doesn't push in the switch that is behind there, this is a safety feature built into a lot of vacuums, to keep people from running the vacuum without a bag in it. Most likely your lid just didn't shut completely. Check for that, and get back to me.
Posted on Jan 20, 2009
Ive used my George GVE370 vacuum twice from brand new,
you do not fix , you returnit as defective and get them to replace or give money back
Oct 29, 2015 | Numatics Numatic George Gve370 Vacuum
Lux 7000 vacuum cleaner power cord light is on and it wont start
Best case scenerio....check and replace the bag...try it. If no bag, it won't start. If that's not it, could be the on/off button or rocker needs replaced and worse case scenerio, the motor is OUT!... I can help! amerivac4u@yahoo.com
Jun 06, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
I lost my instructions to set up the carpet cleaning features. cant set it up
Go to the below site and click on the video clip you need. It's a lot easier to understand than a written explanation.
http://www.kirby.com/Portals/0/videos.html
Jan 01, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Is the roller suppose to continously go around when running? Doesn't seem to change mat in carpet when going over it. Doesn't seem to be much suction..
That means that you need to replace the belt. The belt is what turns the roller brush, and when it is stretched or worn it doesn't. You can get replacement belts here:
Replacement Vacuum Belts
Jan 03, 2010 | Vacuums
How do i replace a kirby vacumme bag?
if you look on the back where the bag goes in the vacuum you will see a strap at the end of the bag, loosen the strap and remove the bag
Apr 22, 2009 | Kirby G6 Bagged Upright Vacuum
Vacuum shuts off, bag light on, runs fine without hose connected
I'm not sure if I understand your problem completely, but if it is your full bag indicator that is coming on, even with a new bag, it's probably your control valve. These can be replaced by your dealer. When working correctly, the control valve should trigger the off switch when the differential pressure gets too great between the front of the bag housing and the area behind the bag. When it goes bad, it will indicate that you need to change your bag, even when you don't. Good Luck!!
Oct 30, 2008 | Electrolux Epic 6500 Vacuum
Motor running extremely hot
You might want to check the brushroll. It may need to be replaced. The brushroll end caps on your model should come off easily and if there is a collection of hair, etc under them and you can clean it out, do so. If it is impossible to clean out, you must replace the brush. You can get one at any Eureka/Sanitaire dealer or warranty station. If you have a model 1934, you can upgrade to a better metal brushroll which won't give you as much trouble.
Sep 24, 2007 | Eureka 1934 Bagged Upright Vacuum
Lindhaus Activa 30-38 Bagged Upright Vacuum Logo
290 people viewed this question
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
