Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Water won't circulate in my Hotpoint HDA3200 Dishwasher Why??
2 Suggested Answers
  • 32 Answers
SOURCE: Hotpoint Aquarius FDW60 won't take in water. Suspected airlock after house move?!?
Try checking the inlet solinoid , should be 1 for hot & cold, sometimes the solinoid will freeze up due to alkaline buildup .try soaking it in CRL , alkaline deposit desolving liquid .
Posted on Mar 13, 2012
Dishwasher Problem
Send it to the agents, bud. It\'s probably an anode or faulty resister on the PC board.
May 27, 2013 | Dishwashers
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
Mar 13, 2012 | Hotpoint 24 in. FDW60 Free-standing...
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Hotpoint fdw65 won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 12, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Water won't circulate inside of the dishwasher. Neither the upper arm or the bottom arm rotate. Water does go in, and it will drain but will not circulate inside.
Check to rotor motor for operation? or a possible belt drive where the belt has failed. Hope this helps Regards Mike
Jul 08, 2011 | Dishwashers
Once the dishwasher had finished the bottom was full of dirty water which won't drain away and now it wont work at all
More than likely a failed water pump, or blockage that has created a discharge problem. This could cause the circut breaker to trip. So, it is kinda messy, but if you drain the water by hand baling, clean or check the interior bottom d/w discharge intake & screen, reset the breaker, and restart. If the system still does not drain it's probably pump failure. I don't think people actual replace the pump, they just get a new d/w unit. Unless there is warranty coverage.
May 25, 2011 | Hotpoint Dishwashers
My dishwasher doesn't work. It won't clean the
It can be your timer, motor, or water value. I need more detail information.
May 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
48 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
