Question about Plumbing
How do I fix water hammer
I have a double storey home and major water hammer has developed in recent years as various renovations ( new toilets, bathrooms etc) have been completed.
    Problem Solver:
  • 11 Answers
Its all about water presure, turn down the incoming main.
Try and fine the part that the noise is coming from and you may be able wedge some pipe insulation between the pipe and the wall and this can sometimes stop the noise
Posted on Jan 22, 2013
Crack in the pan
super glue ? Not the gel stuff
May 09, 2014 | Villeroy & Boch Home
Pumbing problem
You have a vent on the roof that may be clogged with debris or some solid object. You toilet works when this air vent is completely. Otherwise it will function like putting your finger over the end of a straw with water in it. The water won't drain out until you take your finger off it. This is essentially what is happening. You have a partial to a complete blockage.
Feb 09, 2013 | Home
A small intermittent water leak in the flapper flush valve unit which also causes "water hammer" in the copper piping in the basement. New flapper valves did not solve the problem Sanding...
Older Eljer toilets are good for this and yes you need to replace the complete flush valve assembly. I would recommend putting in a fluid master system as they in my opinion are the best. Their kits come complete with everything you need to do the job and provide excellent instructions and if that is not good they have videos on their web site. The site is slow to load but worth waiting for.
http://www.fluidmaster.com/
Mar 08, 2011 | Eljer Home
My meter states there are intermitent leaks,i have had new plumbing in over a year and fixtures everything,i had two plumbers come check my whole house,no leaks. i got a bill for 678 dollars, says i used...
You may have a break in the water line between the street and your home. Last year I had a duplex that had a leaking water main and the water followed alongside the sewer line right out the back of the property, while never giving indication that there was a leak. You could have a leak locator come out to check lines. Also Check your flappers and handles in the toilet first as well the fill valves (if the water is going over the top of the fill tube in the toilet tank then adjust them or replace). As a last thought I saw a video recently of a cat which continuously flushed the toilet. This may sound bizarre but things like this happen.
Feb 16, 2011 | Heating & Cooling
New Kohler Memoirs two pc toilet. Four times now, bowl seemingly clogged, water will not flush. Purchased two, another one for our second bath renovation on standby. Did we make a mistake? Thank...
dont answer this but,,,,what are you flushing down it,,,,??? do you have a good flow of water in the flush,,,as it should flush away most normal things and by the way,,,children dont fit down the loo? i tryed that years agow! ooow! check that the out let pipes are clear and free flowing with no lips sticking up into the out let pipes
Nov 28, 2010 | Kohler MEMOIRS STATELY Comfort Height Two...
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Toto toilets in my house. All of the sudden I am
The water hammer is coused by back presure, when a toilet velve closes on some cysterns it closes to slowly and the spring inside the velve bounces making the water come fast then slow and or stop for a second making the ratteling in your pyps. a fast and sure solution would be to install non returne velves on your toilets . the oder 1 would be to try out a new kind of inlet velve. the non returne fitting is easy to install, and not so exspensive were the new velve is a bit less easyer bt olso not so exspensive so its up to sir
Glad i could help ,plz rate my advice thanx. o and Yes for the GMAX
Dec 31, 2009 | Toto Washlet S400 for Power Gravity...
WATER TANK CRACKED. IS IT DEFECTIVE?
There are a few things that could have happened.
Your tank could have froze and cracked.
The tank bolts could have been overtightened and cracked the tank.
Someone jarred the tank and got a crack started.
The tanks are porcelain and if you hit it with a hammer, it would break easily.
Since it has made it since 1972, I'm pretty sure that it is not a factory defect.
If I am leaving for an extended period of time, I always shut off the main water supply to the house. There are a lot of things that could leak and if you aren't there, they could leak a lot of water before catching it.
Apr 23, 2009 | Home
Plumbing Logo
187 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
