I have a dayton fuel trimmer Model# 3E371D hanging furnace. when you give it a signal it fires up the fan kicks on and the unit will run 10-15 min and then before reaching the set point on the thermometer the fan kicks off but the burners stay on and you have to shut the thermostat off or the high heat switch will trip. After waiting 10-15 min and turning the thermostat back on the unit will fire and run perfectly for another 10-15 minutes before repeating the cycle. Any help would be appreciated.
3 Suggested Answers
SOURCE: FURNACE CYCLING ON AND OFF ..
it sounds like you have a dirty or faulty flame sensor im assuming that you have inshot burners in your furnace the flame sensor will be on the right or the left of the burner assembly opposite the pilot and ignitor it slip through the burner assembly and attaches to the burner it is l shaped steel that is fitted in a porcelin housing and when installed correctly it will be directly in front of one of the inshot burners when the main burner lites the flame touches the sensor and holds the gas valve open until the thermostat is satisfied remove it and sand the the l shaped metal end with 100 grit sandpaper until its clean and shinney then reinstall set thermostat to heat and see if it will stay lit if not get furnace brand model and serial# go to local hvac parts house and pick a new flame sensor if its a rheem i generally pay about ten dollars each my cost chances are cleaning will take care of the problem. good luck! hvac ike
Posted on Jan 20, 2009
shastalaker7
  • 1515 Answers
SOURCE: no heat coming from furnace,
Hi, this unit if you say hot surface ignitor has no standing pilot for you to light. Yes, the fan will run in the on position. Turn it back to auto. Leave it off. You will need 2 people, this will be easier for you. Go to the furnace and see if you have a round inspection hole to look through. If so, see if you see a red led light. Yes or know. Remove the panel to where you can see the circuit board, burners lined up and so on. Some units have a panel switch on them so when you remove the panel, it kills power to everything. It would be around the perimeter and you will need to tape it down real good. Now, have someone turn the thermostat to auto/heat and turn the heat up high. I know this is a Carrier with a hot surface ignitor, so you should be hearing the small inducer motor start running. If you did have a red led light and it is flashing, you will have a code sheet glued to the panel, a error sheet to tell you what is wrong, like if its flashing 3 times fast and 1 time long and slow you would look at chart and it will say what to look for. Some units have them and some don't.Anyway, the inducer motor comes on first, it has a clear plastic tube coming from it going to a pressure switch. If the motor is on and the tube is clean, no water, condensation in it, it goes to the switch and closes the switch.When it closes, it will send a command to the main controller, circuit board or a module to send power to the hot surface ignitor, which will glow and send a signal back to open the pilot valve(PV). There is a porcelin flame sensor next to the ignitor that has a metal tip which heats up and tells the main gas valve the pilot is on to open up and send gas from the 1st burner over to the 2nd and so on. This is the sequence of operation. We know the stat is good, and the blower motor is also good, so all we need to do is find out why the furnace wont light and run. It may have a flame roll out switch on it that has tripped. It has a reset button on it. Make sure the gas valve and gas is on before you do this test I am walking you through. Try to have a helper. Remember the door switch if it has one. This should be a easy fix, so get back to me and keep me posted on what is going on. I will wait to hear from you. You can do this.
The best to you,
Shastalaker7
Posted on Apr 11, 2010
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Furnace fan runs costantly
Check to see if fan setting is summer or winter.
Feb 05, 2012 | Dayton Gas Furnace Heater
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
heatman101
Feb 02, 2011 | Dayton Gas Furnace Heater
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
I have a dayton fuel trimmer furnace model # 3E438A and the problem is that upon ignition to the furnace the unit runs and after about 3 minutes the units inducer fan shuts off and the flames stays on....
It sounds to me like your draft motor is probably shuttimg off on thermal overload. They will get to hot and shut down until the motor cools down then run again.But by that time it's caused other trouble so I think you need to replace the motor first and then see what other problems it has caused.I hope this helps you and thanks.
Jan 10, 2011 | Heating & Cooling
I have a dayton fuel trimmer gass furnace in the garage. the electonic ignitor does not light the furnace. the fan will come on after about 5 min. the number on the name plate is 3e406d
after fussing with the furnace for a couple of weeks of double checking everything i found that the switch for the exhaust was triped. i had checked it 3 times and i thought that it was in the reset position but i found that when i reset it with a pocket screw driver that is was not reset. thanks for the information on your sight.the furnace has ben working for the last 2 weeks with no problem. the dogs will be happy this winter
Nov 17, 2009 | Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
