Question about Hotpoint HSS25GFP Side by Side Refrigerator
I am not getting water to the dispencer the water goes to the
Bottom of thedoor connection
  • 410 Answers
Its possible that the water tank has frozen up inside your ref compartment. here is how to fix. remove teh lower veggie drawers and then look behind where the drawers were you will see either a water tank or a roll of plastic tubing. using a hair dryer heat the tank for a few minutes then try you water dispenser again. once you have it working just raise the temp of your refrig compartment to prevent future freezing of the tank. peyton
Posted on Jan 20, 2009
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
My kenmore he2 wont dispence the soap in the soap dispencer
Evening to you
Allow the washer to start a cycle and have the dispenser drawer ajar and observe through which dispenser the water goes.
Does the first stream go through the pre-wash dispencer,secondly notice where the main stream goes and lastly where the softener would go. If this can help you in any way just put use the dispencers as fits the washing.
goodluck
Kolbrun
Feb 26, 2012 | Kenmore HE2 Washing Machines
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
Whirlpoolside by side mdel no ged22dqxdwoi
this is not a fun task but can be done first you have to remove the door then remove the ice dispenser from the door cover/levers etc... just a couple of screws. the on the bottom of the door in the tubing. Tape (electrical tape is best) a piece of wire clothes hanger inside the old tube and inside the new one then fish it thru the door this may take a few times and may require some one to help you but if the hole is over 2 inces from the door and you can cut it out they make a quick coupler to repair the tubing with just a knife and your fingers.try that and let me know how it goes
bill
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore model 106 9555710 SxS - no wate through door
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispencer not working
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water dispenser lg gr-602tvpf
I also have the same problem. No water but the ice maker works.
Jan 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
93 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
