Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Troubleshooting no-spark DESA heater transformer
I have a Reddy 55,000 BTU Kerosene spark-plug fired heater, model R55, which has a no-spark situation. I'm trying to troubleshoot the problem and I need details on determining whether I have a grounding issue or a transformer issue. I'm concerned that my garage outlets may not have a grounded third prong (that they're just for show) and I'm not sure if this would cause a problem. With the transformer removed and "bench testing" it I'm getting these resistance values: Primary: 9.7 M ohms Secondary: 1.16 K ohms I measured 118V input with the transformer REMOVED, but I did not test the same input with the transformer installed. How should I go about testing continuity of ground and my transformer? Transformer model is 098024-04 Thanks in advance!
  • 226 Answers
SOURCE: 60000 heater kerosene fires up but shuts off shortly after
Check the entire fuel like to the tank. They tend to break, plug up, etc. which causes a lot of problems. The strainer in the bottom also plugs up. Rick
Posted on Apr 11, 2009
  • 132 Answers
SOURCE: I have a 55,000 BTU Kerosene heater that will not
The fuel is drawn from the tank by vacuum. If there is any kind of dirt in the fuel or tank, it will clog up that tube and not fire up. Also there is a foam filter at the rear that could be dirty. There is also a reset button by the filter that needs to be reset every time it runs out of fuel.
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: i have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
tbugger
  • 232 Answers
SOURCE: Reddy Heater R55 55,000 BTU
If you brought the heater to my shop with the great (no lie!) description of the problem we would immediately grab a flashlight, shine into the tank and look for water droplets rolling on the bottom of the than. (Keep in mind that a layer of water can be on bottom & not show up with the light)
The next thing would be to use soapy water and try to find a crack in or around the plastic cover and move all the way to the nozzle looking for an air leak. 3.4 at the gauge doesn't mean the air is going all the way to the nozzle.
Next, remove the top cover. Does the heater run fine once removed? If so, replace the worn out nozzle. That heater has some age on it and DESA recommended annual replacement.
The filter is more of a strainer than a filter. It is hollow.
Read more troubleshooting tips.
Posted on Nov 10, 2010
Testimonial: "Thank you tbugger for the fast and informative response I will follow your suggestions. THANK YOU VERY MUCH FOR YOUR HELP!!"
jcameo7270
  • 675 Answers
SOURCE: my kerosene 50,000 btu reddy heater fires up for
There is a sensor inside that tells the heater that the flame is lit...if it doesn't "see" the flame it will shut down...this may be caused by the filter in the rear being clogged and it is not allowing the pump to produce enough pressure to ensure a good flame or the pump inside may have sucked up some debris and is now not producing the proper pressure required. Another possibility is that there may be enough dust on the sensor itself to cause it to not "see" the flame...if you take the cover off you can find this sensor...it will have 2 wires coming off of it and it looks like a photocell...it should be located just in front of the jet where the fuel comes out...a word of caution...the ignitor(and the spark plug looking thing) have very high voltage on them(around 5000Volts) so I would avoid touching these parts while in operation.
Posted on Dec 08, 2010
Reddy Heater R55 55,000 BTU heater spits and sputters but CONTINUES TO RUN. Air pressure is at 3.4 (was 4.0). new lines, Plug is firing well, fuel is old but clean. My question is: is there supposed to be...
Nov 10, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Hello, I have a 55,000 BTU kerosene heater, model # R55 It will not fir or ignite when I plug it in. Just paid $10.00 for a guaranteed online answer and have not received one
Take air preassure from a compressor and turn the fan blades in the back of the motor while you reset the switch. the you know its gumming up and needs to be cleanned and changed parts or a kit added from your local lawnmower supply house.
Jan 31, 2009 | Desa International R40 Utility Heater
Kerosene Reddy Heater, fan comes on, but it won't ignite, it just blows kerosene out the front. There is no electricity getting to the plug. Please reply soon, I need it tomorrow!! Thanks
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
1,278 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Outback Jack
Outback Jack
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
