Question about Whirlpool WED9600T / WED9600TA / WED9600TW Electric Dryer
Whirlpool duet dryer wed9600tw acts like it has no power to it, later it will come on and work fine
My dryer is only a couple years old, but here lately I can go to push the power button and it does nothing. The drum light doesn't even come on. It's like it is completely dead. It will make small clicking noises at times? Then I can push the power and it comes right on and works great! I need to know what's wrong, because I'm tired of having to rewash clothes bc the dryer might take so long that they start smelling. Any suggestions?!?:)
  • Amanda Williams Jan 07, 2013
    It looks like all the wires are connected securely! Any ideas??
  • 1,383 Answers
It' sounds like it tripping the thermal. so you might need to get into the heater and clean out the debris AND sweep the exhaust pipe
see these http://www.homedepot.com/p/Everbilt-Dryer-Vent-Cleaning-Kit-DVBRUSH12K-6HD/205047060
Posted on Jun 09, 2017
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
I have had my whirlpool front loading dryer for about 5 years. It worked fine for a couple of loads and then when I started to dry the next load, it won't come on. It just beeps, checked the breaker,...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool Duet dryer will not power up
Check your thermal fuse if no continuity through it then change it, it acts just like a car fuse. If it blows you can't see it you have to test it with a continuity tester. Go here and see what it looks like www.repairclinic.com/SSPartDetail.aspx?s=t-gew9250-%3d%3di2986&PartID=2986
Mar 12, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer not heating
The first thing to do would be to check if the element is broken. Most dryers have a couple of screws that hold the top, and it opens like the hood of a car. The next step is to remove the drum, usually a couple of screws holding the front.
Jul 20, 2008 | Whirlpool GEW9250 Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool WED9600T / WED9600TA / WED9600TW Electric Dryer Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
