Question about Sharp LC-37DB5U 37 in. HDTV LCD Television
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
All the buttons on the remote and tv seem to work except for changing the channel or when you press the ENTER button to adjust or change anything like the EZ setup . Any ideas?
  • Sharp Master
  • 933 Answers
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Posted on Jan 06, 2013
  • andrew cloutier Jan 06, 2013
    Both TV and remote buttons will scroll to everything there is but when you hit the enter button, nothing happens. Thanks
  • Back2life Electronics Jan 07, 2013
    Do you have access to another remote?
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: blue screen, no video, but has sound
blue screen no video but has sound
Posted on Feb 03, 2009
  • 1779 Answers
SOURCE: Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Posted on Jul 09, 2009
No picture
The power supply is failing. The clicking sound indicates the power supply is attempting to start but can't.
Jan 14, 2014 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
I plug in the cable/antennae wire and it freezes up. I can't change channels or anything. if I unplug it it changes fine, then of course I can't watch tv. I have a sharp lc-s3sb23u.
See if Sharp's customer service still walks customers through what is called an INIT or factory reset. 800-BE-SHARP. Make the television do what it does when it freezes up and then call. You might just need to scrap the television because if you need another main board the part alone will cost around $600.
Sep 20, 2011 | Sharp LC-32SB23U 32 in. LCD TV
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp tv opc light stays on
I have an opc light that stays on. My cable channel input will come on briefly then picture and sound shut off but the dvr works just fine.
May 01, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
My TV sems "stuck on a channel" and it iwll not move up or down and it is not responding ot either the tv controls or the remote. It is Sharp LC-32SB24U TV
Tries Unplug the tv and all devices to this tv.Replug it back about an hour later.Than goto the tv menu.Go to PICTURE go down to reset.It will reset the tv back to factory setting to the tv,everythings should work as before,not then ur tv manual control senor board or the Tuner board have problems,must be replaced to solved this.
Jul 05, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Sharp aquos has sound but no picture
you may have a bad signal board, .you can get on ebay, but check your exact model first
check here after get your part #
http://shop.ebay.com/i.html?_nkw=+LC-42D62U&_sacat=0&_trksid=p3286.m270.l1313&_odkw=LN-S4695D&_osacat=0&bkBtn=
Fosg2000, please rate me
Apr 26, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Jan 10, 2008 | Sharp Aquos LC-32D40U Television
Sharp LC-37DB5U 37 in. HDTV LCD Television Logo
567 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
