Question about Samsung Computers & Internet
Samsung reboot loop - Samsung Computers & Internet
  • Samsung Master
  • 27,725 Answers
Laptop or Desktop computer ?
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty. even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly. Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be running your computer over its limits causing memory dumps also under processes see what is ticking over in the background you might have a virus again if you see something you dont need to be and users you will see who is using your computer
You might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility of the ram before making any purchase Might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/
Hope this helps.
Posted on Jan 06, 2013
My galaxy tab A keeps booting on start up like it keeps showing Samsung and keeps repeating? How do I fix it?
Plug into charger hold power button down until device powers down
charge fully then disconnect and power up
might work or look at this site to erase cache entirely
https://appauls.com/how-to-fix-the-samsung-galexy-tab-reboot-loop/
Nov 04, 2016 | Samsung Tablets & eReaders
My tablet will not turn off. It keeps restarting but will not get past the iRola screen.
About 15,600,000 results (0.52 seconds) Search Results
    The tab is in an endless reboot loop. - Samsung Galaxy Tab ...
    https://www.ifixit.com/.../The+tab+is+in+an+endless+reboot+loop.
    iFixitMy samsung galaxy tab 2 7.0 is turning on and off continuously. ... The second iteration of Samsung Galaxy Tab tablet computers with a 7.0 inch screen. .... to lose all the data, but still it does not lose and keep restarting over and over again.
    it keeps switching itself off - Samsung Galaxy Tab 3 10.1 - iFixit
    https://www.ifixit.com/Answers/View/.../it+keeps+switching+itself+o...
    iFixitMy Samsung galaxy tab 3 charges badly and keeps turning off and not coming ....What you will need to do is take the tablet apart, (carefully) and secure the battery to..... It shuts itself off and I have noticed that upon restart the Wifi is turned off.
    How to fix any Samsung Phone/Tablet that keeps rebooting ...
    ? 3:03
    https://www.youtube.com/watch?v=A-0LgvM-WNs
    May 30, 2014 - Uploaded by lennonSystems
    How to fix any Samsung Phone/Tablet that keeps rebooting(Boot Loop). lennonSystems ... with the s3 it does not work. trow it in the trash can ... When my phone does this I just let it do its thing, after a while it would stop.
Feb 09, 2016 | Tablets & eReaders
My samsung flight keeps rebooting, its like a never ending loop. I can take out te battery and try to charge the phone. but it keeps looping.
i had this same problem with my samsung flight it turned out my battery works just fine but wasnt stable enough in the phone it has to really be in there tight as hell so what i did was tape the end without the 3 bars with 4 layers of electric tape so now its a very tight fit and cover it with the case. if this doesnt work your ohone is dead
Aug 01, 2011 | Cell Phones
Cell phone reboot in loops If I install my Canadian Sim cart
You can always do a Full Factory reset on the phone with a master code. Keep in mind, this procedure will erase all data. *2767*3855#
Rate this.
Dec 24, 2009 | Cell Phones
Samsung (samtron 5Ei ) rebooting & EMI problem at times it is O.K.
Check 5 v at 7805 output and change Memory IC (EEPROM).
Check SMPS o/p voltages
Sep 20, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung f500 phone
try this code *2767*2878#
this will solve your problem
Mar 12, 2008 | Samsung Cell Phones
Computers & Internet Logo
60 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
