Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Prints a black rectangle over picture
I have the Kodak ESP 5 AIO Printer. When I try to copy something it prints a big black rectangle over the entire copy. This is a recent development because I have made a copy before and it worked fine.
  • hessmelclay Feb 03, 2009
    The light didn't come on, and the black rectangle is still there. I don't want to keep wasting my black ink cartridge on solutions that do not work. I can print from the computer fine, but I can't scan or copy. Is this printer defective???
    Champion:
  • 320 Answers
SOUNDS LIKE SOME THING IS BLOCKNG THE LENS OR THE SCANNER MAY NOT BE WORKING 100% OPEN THE COVER AND LOOK AT THE GLASS AND PUSH THE COPY BUTTON AND TRY AND LOOK AT THE LIGHT THAT COME ON MAKE SURE THEY ARE COMING ON GOOD LUCK
Posted on Feb 03, 2009
How can I over ride my ink level tracker on the Kodak ESP 7 printer? The printer must be using a counter because I never print in color but my color cartridge keeps showing that it is going down. ...
The Kodak printers are designed in such a way so as to work with combination of Both color and black ink..In other printers,the prints are not that sharp,but In kodak printers color are awesome because even if we print black and white,the color from the color ink is also taken to give you those lifetime prints.Unfortunately There is no way to overcome this ink indicator.You cans et the preferences in the printer settings to print in black and white in your computer .
Dec 30, 2009 | Kodak ESP 5 Printer
Kodak ESP 5 new cartridges color prints fine black will not print. Only have used Kodak replacement cartridges. How can this be fixed.
Try cleaning the printhead.
Press Menu > Select maintenance > Select clean printhead.
If still black does not print, call Kodak tech support, printhead will be replaced free of charge
Nov 22, 2009 | Kodak ESP 5 Printer
My kodak AiO esp 5 Printer prints the test page correctly but will not print anything from the computer - it says that has printed and makes the noises and acts like it's printing but the page comes out...
try to clean the printhead of your printer for you to clean the pritnhead you may launched the home center on the upper right corner click the help icon(?) then select maintenance and click on clean printhead.
try to print also a sample picture using the home center.
if this issue not solve tyr to reinstall the software and the driver of the printer or call kodak toll free 1 800 421 6699
If you can print a test page using a printer it means printer is working fined. You just need to concentrate on the software or settings form the computer
Nov 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 7 Stops printing at 97% done
I can understand your concerns. Just try to copy a document from the printer , by placing it on the scanner glass of the printer and by pressing Copy on the printer.if it copies,that means the printer is working absolutely fine.As far as the printing from computer is concerned,i would recommend you to
Kindly go to control panel-add or remove programs and then remove bonjour,Kodak all in one printer software and microsoft.net framework Go to start,go to run and type in "services.msc", without the quotes in the open box and press ok. restart the following services by clicking on stop the service and start the service. 1. background intelligent transfer. 2.cryptographic service. 3.windows installer. 4. remote procedure call locator. 5. printer spooler. make surethat they are set to automatic not manual.
install the latest version of Kodak software from www.kodak.com/go/downloads Your issue will be fully resolved.
Mar 30, 2009 | Kodak ESP 5 Printer
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
66 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
