I need programming code for my urc 1056 remote to control Sony dvd dvp-sr510h
Code to control Sony DVP-SR510H
IrishDruid
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
mewms_14904
  • 1027 Answers
SOURCE: I need codes for a magnavox dvd player.
Magnavox 0503, 0675
manual
page 18
Posted on Jun 05, 2008
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
Posted on Sep 01, 2008
SOURCE: codes
I NEED CODES TO PROGRAM MY TV W/ REMOTE CONTROL URC-4021BOO
Posted on Feb 02, 2009
SOURCE: REMOTE CONTROLER RM-YDO10
remote controler car that uses gas
Posted on Apr 10, 2009
I purchase sony cd/dvd player DVP-SR510H at walmart today -- the music CD loads -- but there is no sound. DVDs work fine.
is this happening to all cds or just that one.
because if the sound is working on the dvd then you should have sound from the cd.
have you checked the manual to make sure it is all setup ok.
Dec 12, 2016 | Sony Televison & Video
Sony DVD player SR510H hook up to Panasonic TV but no sound or picture
Describe your "hook-up" hardware. Make sure you are using "out" socket or HDMI plug-in socket at back of DVD player.
May 22, 2015 | Sony DVP SR510H - DVD player
I can't get the menu on my DVP-SR510H DVD player. It came up in Spanish.
Did you try the "Reset to Factory Settings"? It worked for me once.
Mar 02, 2014 | Sony Televison & Video
Sony remote setup
The remote could be defective or could even be the wrong one for your Sony player.
Feb 21, 2014 | Televison & Video
I need the dezoning code for a Sony DVP-SR510H DVD player.
You maybe able to get a region free code off these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 01, 2013 | Sony DVP SR510H - DVD player
Sony DVD Player not working
The controller board is slowly dying. I think it might be time to buy a new DVD player.
Aug 19, 2012 | Sony DVP SR510H - DVD player
Televison & Video Logo
355 people viewed this question
Top Televison & Video Experts
Electro Med Services...
