Question about Transcend StoreJet Computers & Internet
PC unable to read Transcend external hard drive - request formatting of drive
Initially recieved error messages when using external hard drive - but continued to use and read external hard drive. On one occasion checked option to conduct scan of hard drive and automatically repair error. From this moment on PC unable to read hard drive. Recieve message requesting format of drive before using
  • Transcend Master
  • 27,725 Answers
Is it a usb drive or an external drive with a usb lead ?
Transcend have a life time warranty on all of there products
If its a usb drive
Figure out whether you need a hardware or software fix. Look for grinding sounds from your drive or humming that starts or stops. These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out. If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix. Run one of the many software fixes, if you think the problem is related to software. These programs feature on-screen directions, making it easy for you to progress through them. If this works, you don't need to fix a physical problem. Remove the many tiny screws that holds the drive together. Eventually, you'll get to the innards of your drive. Be very careful not to bend or force a piece to go where it doesn't want to. Determine if you've set things straight. Look to see whether anything was loose inside your external hard drive. If you have recently dropped it or traveled with it, it is possible that something came loose. Also check that all the arms and platters are straight and do not appear bent in any way. If they are bent, straighten them with your hands or pliers. Put everything back together and check that everything in your external hard drive is working properly. Try using the external hard drive on another computer. click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. There are also Data Recovery programs that might be very helpful to recover your important information. Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage Hope this helps. b>
Posted on Jan 06, 2013
    New Friend:
If your precious data is lost or missing, so don't worry about it, Just download this data recovery software http://www.datarecoverysoftware1.org/ in your machine after that user can easily recover your hard drive data with the assist of this remarkable application.
Posted on Nov 19, 2013
    New Friend:
  • 37 Answers
1.your usb cable may be faulty so replacing it may solve problem.
2.change external case .
click here
Posted on Mar 23, 2013
    Novelist:
  • 241 Answers
No need to be get tensed about data, Once you have performed formatting you can still recover data from it. One such tool can be downloaded from http://www.recoverdata.org
Posted on Jan 18, 2013
TakeTechsol
  • 3 Answers
SOURCE: simpletech 500 external hard drive
hi
Posted on Jan 08, 2008
  • 10406 Answers
SOURCE: I have formatted my transcend
Windows is not configured to "show hidden and system files",
but you can change that option.
Download the software from Transcend's web-site.
Posted on Nov 02, 2010
darshanks
  • 40 Answers
SOURCE: formatting the 8GB Transcend pen drive
check once whether u hv given read only option in properties
Posted on Jun 30, 2009
ChungYu
  • 76 Answers
SOURCE: My 500 GB store jet
You will need to format the disk so the file structure can be read by your operating system. Formating the disk will wipe all data from the disk but will only need to be done once.
Posted on Mar 01, 2011
ChoiceSmith
  • 30 Answers
SOURCE: I have an external hard
Firstly,recover your data on the external hard drive with third party data recovery software.Then you can format it to check out whether it can be fixed.
For data recovery program,I have a professional one on my computer that can recover data after deeply scanning your hard drive to look for lost data due to drive crash,system sabotage, virus attack etc.You can download it and scan your hard drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Posted on Aug 04, 2011
When i'm trying to format 2 gb transcend memory card , its showing error message that "unable to format"
Try to format your USB drive with this low level format tool -> http://filecom.net/utuHnxW
Remember to select the correct drive because it will erase all data.
Aug 17, 2013 | Transcend Computers & Internet
IO error
The message "The Request Could Not Be Performed Because of an I/O Device Error" appears when Windows is unable to read the data on a storage device.
If this error message appears when attempting to access the files on an input/output
(I/O or IO) device, such as an external hard drive, the file system on the drive could be damaged, the drive could be infected with a virus or the data connector inside the device enclosure could have come loose.
If troubleshooting the drive fails to fix the IO device error, formatting the drive might repair the device.
Connect the external hard drive to the computer.
Run an antivirus program.
Click the "Scan" tab or button, then click "Custom."
Uncheck all items in the list except for the drive letter assigned to the external drive.
Click "OK." Click "Scan" or "Scan Now" to run a virus scan on the hard drive.
Quarantine or remove any infections the virus scanner detects.
Click "Start." Input "cmd.exe" into the search field.
Press "Enter" to open Command Prompt. Input "chkdsk <drive>: /f /r" into Command Prompt.
Replace "<drive>" with the letter assigned to your external hard drive.
Press "Enter" to run CheckDisk on the drive.
CheckDisk will search for and repair detected errors or bad sectors.
Burn the files on the external hard drive to a set of DVDs or move the files to another drive, if possible.
If the IO device error reappears when attempting to move the files, disconnect the external hard drive from the computer.
Remove the power adapter from the drive.
Check the documentation included with the drive for instructions to take the drive apart.
If no instructions are available, contact the manufacturer for instructions or find out if disassembling the drive will void the drive's warranty.
Remove the screws securing the faceplate to the drive or from the edge of the enclosure. Insert the edge of a small, flathead screwdriver in between either side of the enclosure to wedge both sides apart.
Check the connections to the drive.
Confirm that the IDE or SATA interface is plugged into the back of the drive.
Reassemble the external hard drive, reconnect the power adapter and reconnect the drive to the PC.
Attempt to access the files on the drive.
If the IO device error reappears, return to Command Prompt. Input "format /fs:fat32 <drive>:" into the command-line prompt.
Replace "<drive>" with the letter assigned to the external hard drive.
Press "y" when the message "Proceed with Format (Y/N)?" appears.
The process will format the drive, erasing all data on the disk.
If the drive still fails to function after format, you will need to replace the drive.
Hope this helps
Nov 25, 2012 | Western Digital WD5000AAVS 500 GB SATA II...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I am using Transcend 320 GB external hard disk in a Windows 7 Operating system. It is keep on asking me to format the disk while i plugging in to laptop. Unable to see the contents in the external hard...
guess you are using a USB port to for that.....
1 - check the cable that connects the HD to the USB port...change the cable and verify
2 - connect to another PC and check if it's ok there
3 - bring another ext HD from a friend and try conencting that....check if that's OK
4 - there could be a corruption in the HD that is preventing the PC from reading it
cardinal rule for USB....not a very dependent device specialy if connecting thru USB data cables....
solution
always use a good qty USB data cable compatible with USB2....as some cheap cables are only for USB1
visit my website
www.sureshayyar.110mb.com
for more info on PC issue and solutions...
reg
Kris
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi.- My transcend external hard drive its not working. It doesn't show the icon to acces to the information that I have stored on it. I'm very worried because I need the info and this is not...
Hi There two chances
1. You pen drive might have damaged
2. Either your external drive or PC is affected by some virus which wants any external drive connected to be formatted
I request you to check the drive by connecting it to some other PC other than yours and tell me the result. I can guide you to get the data
Thanks
Oct 19, 2010 | Transcend Computers & Internet
MAC unable to read this storejet device
try the device on another Computer, if that fails then you might have a faulty device
Mar 28, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
When I am put my 8 gb Transcend usb deive into pc, the message come ''u need 2 format the disk in drive I:b4 u can use it'' ,ten I click on format disk, a message come ''windows was unable 2 complete the...
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Mar 19, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Formatting the 8GB Transcend pen drive
Jun 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
1,378 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
