Question about Sport & Outdoor - Others
20 year old jackaroo tent, no manual and missing poles
Dont know the name, has a number 5/T0050, tent is perfect but there seems to be poles missing, hasnt been used for 15 years and can't remember what it looks like up.
MNfisherman
  • 11896 Answers
SOURCE: Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
Posted on Jul 06, 2009
SOURCE: ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Posted on Aug 20, 2009
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
SOURCE: I have a greatland tent item #15710. This is a two
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Posted on Sep 20, 2009
SOURCE: where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Posted on Dec 13, 2009
Where can I get tent replacement poles for a Ted Williams blue canvas tent sold by sears as they don't have them?
How old is it? (Canvas suggests that it is very old and has not been produced for many years.) If it is more than a few years old, the only way is to find a supplier that will make custom poles to fit most tents. But that can be expensive, and so you might want to just find a new tent that you like. Don't spend a ton of money on an old and possibly very leaky tent unless you know that it will keep you dry.
Feb 27, 2015 | Camping, Backpacking & Hiking
I need replacement poles for old model melty tents
It is likely to be difficult to impossible. Expect that it might be fairly expensive. Contact Kelty at:
1-866-349-7225.
In Canada, email: Canadacustomerservice@Americanrec.com or call 1-866-349-7225 x 3726
Apr 13, 2014 | Kelty Pagoda 4 Tent
I have a magellan yukon (23-010) 20'x9' that has some broken poles. Where can I replace the poles
You can replace tent poles. I've never used them, but you can try http://tentpoletechnologies.com/. Otherwise I would suggest buying replacement poles from Academy (who makes the Magellan Outdoor line) or trying to find generic poles and an sporting goods store. Best of Luck!
May 31, 2013 | Magellan Outdoors Yukon II Cabin Tent
Hillary ten person family tent
Step 1 Choose a spot to set up your tent. Look for level ground that's free of large rocks or other debris. Make sure you're safely away from your campfire. If it's possible, pitch your tent away from your kitchen area as not to bring animals too close should they be attracted by the smell of food. Once you've chosen a spot, clear the ground of small rocks and sticks to give you a comfortable floor to sleep on. Step 2 Unroll your tent. Put the rainfly and poles aside. Open the tent body so it lays flat on the site you chose. Orient the door so it faces in an accessible direction. Step 3 Take out the tent poles. A basic Hillary tent will use two long poles for the tent body and one short pole of the rainfly. Assemble the two long poles and thread them through the pole guides on the tent body, attaching them to the holes in each tent corner to raise the tent. Step 4 Open the rainfly. Assemble the shorter pole and guide it through the top of the rainfly. Place the rainfly on top of the tent and secure it to the bottom of the tent body with the attached hooks. Step 5 Stake down your tent. You don't want to be surprised by a storm in the middle of the night or while you're away from camp. Stake your tent even if the weather is clear when your arrive. Use a stake at least in each corner of the tent. Find a rock to hammer them firmly into the ground.
Jul 24, 2012 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
    I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
    Paul.
    Dec 23, 2010 | Sport & Outdoor - Others
    Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
    I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
    May 19, 2010 | Toys
    I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
    Jul 21, 2009 | Sport & Outdoor - Others
    Where can i get assembly instructions for great outdoor tent
    Dec 22, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
    Sport & Outdoor - Others Logo
    107 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
