Broken Merlin 430R Roller Door Opener
I have a Merlin Prolift-Model 430R roller door opener, one of the remotes is broken. Where would I be able to buy a new remote and how can I program it myself.
Dave Duff
  • 30 Answers
SOURCE: Lost Dominator Garage Remote
Hi There,
If you can handle a screwdriver and a pair of snips, I think you may find this item on ebay useful.
Item number 380001856331
Hope this helps
Cheers.....Dave
Posted on Mar 11, 2008
  • 18 Answers
SOURCE: remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Posted on Dec 08, 2008
SOURCE: Replacement for Garage Door Remote
The red button is the "learn" button. No resets.
Posted on Mar 25, 2009
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Posted on Apr 26, 2009
  • 3197 Answers
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Posted on Jun 01, 2009
The light stays on
guessing it is a sensor issue. the safety sensors
Aug 23, 2015 | Building Materials
How to program a remote control for Merlin Garage Door
Each manufacturer of aftermarket remotes for Overhead doors has a specific sequence for a specific door opener mfg and model #. And those sequences are include in the printed matter in the packaging of the remote. If you have Merlin remote and Merlin opener contact the local Merlin installer for the sequence.
Oct 13, 2014 | Building Materials
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
Can I get a replacement remote control for a Merlin Powerlift roller door model 2500L 1/3 horsepower
Check out this site.
http://www.retro-remotes.com/apps/webstore/products/category/365891
Apr 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
The cable unwind on the roller,does it means the s...
You should be able to tell if the spring is broken by looking at them.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener won't open all the way
Several things come into play depending on how far it opens. You could have a broken door spring, a bad drive gear or just an opener that is showing signs of neglect. If you can eliminate the springs and the gear then you might need to lubricate the roller bearings and all the door hinges. There is a control on the rear near where all those white wires go that can increase the force the motor will apply to open the door.
Nov 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
