Question about LG Large Capacity Free Standing Black Electric Range - LRE3023SB
LG Range Model LRE3023SB wont get hotter then 300 degrees
What are the operating pressures on an Armstrong Concept 10 scua24 A/C
Didn't help ya huh Wayne?? We are in the temperature control businesses, temperature is what's important, not pressure. The hotter something is the more pressure it has. On a satisfied home, I will say 75 degrees, your evaporator coil should be around 40 degrees. 40 degrees with r22 is about 65 psi. 40 degrees with 410 is about 125 psi. Head pressure, your condenser temperature, will vary depending on the time of day. The hotter the temperature, the higher the pressure. R22, 200-225-240...R410a, 300-325-350. Keep in mind, the hotter the house, the higher the pressure. Hope this helps!!
Jul 08, 2017 | Heating & Cooling
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Hi, What does problem code B0116 mean. Its a lexus ES300 1999
ect fault engine coolant temperature sensor circuit range/performance fault. you need a new ect sensor.if you want to test is with a ohm meter here is specs starts at 30k ohms at -4 degrees it will goto 0.2k ohms at 212 degrees F so the hotter it gets the less resistances it gets. it is like 15-31 bucks at local parts store and no hard to change.
Jul 13, 2010 | 1999 Lexus ES 300
Older ge spacemaker range, temps wont boil water on stovetop, oven takes hours to hit 300 degrees could it be wiring or thermostat? says pn PLT135-3 owners manual [dont have] PLT059-2 model number...
Check your breakers to the oven. It sounds like one of the two of them have tripped and you are only getting 120 VAC.
Do you have a volt-ohm meter, and know how to use it?
Dec 18, 2009 | GE Spacemaker JMP28 Electric Kitchen Range
Range will default to 165 degrees
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Dec 07, 2009 | Kitchen Ranges
Does not hold oven temperature
I have the same problem. I had a repairman come out and they told me it was the control panel and thermo sensor. Replaced both and still didn't fix the problem! Can't return the parts and now into the stove for over $370! I wish I had put that money towards a new stove :-(
Mar 29, 2009 | LG LRE30453ST (Electric) Stainless Steel...
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Engine running hotter than usual
first check your axillary fan for function,if change your thermostat element look at the bottom you can see what degrees open the element,you can buy element with lower degrees.axillary fan working,first stage when aircon is on.
Feb 19, 2009 | 1985 Mercedes-Benz 300
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
LG Large Capacity Free Standing Black Electric Range - LRE3023SB Logo
23 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
