Question about CyberPower 485VA UPS Backup (BE485) UPS System
My system's surge protected outlets are working but the battery backup outlets are not???
5 Suggested Answers
flopez
  • 161 Answers
SOURCE: CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Posted on Sep 21, 2007
JonwVBFL
  • 56 Answers
SOURCE: Battery/Surge outlets not working...
Sounds like the UPS battery is bad, or the circuit break on it has gone. Is there a reset button on the UPS? Do you have the program that came with the UPS to check the battery status, those programs typically let you run a test on it also.
Posted on Jan 30, 2008
  • 26 Answers
SOURCE: CyberPower 325SL backup system
That's a tell tale sign of wornout batteries. They last about 3-4 years in a UPS like this. Here's a replacement: http://www.batteryinternational.com/cyber-power-cps325sl-ups-battery-ups-batteries-f1.html
Posted on Oct 23, 2009
  • 72 Answers
SOURCE: why does the 4 outlets (surge only) of my
The battery only works when it isn't plugged into the wall. That's what a battery backup is for,so when the power goes out, the battery kicks in.
Posted on May 08, 2011
Not working when plugged
Most UPS's have split power. One is for Surge protected which is probably the half still working. The other come from a switching device called a relay. The relay is on the circuit board inside. If the battery backup'd half is dead, then that relaying is not connecting the power source to the three outlets. It could be due to a defective control circuit or the relay is bad. If you dont know electronics, either buy a whole new unit, or send it in for a rebuild with a place that knows what they doing. The manufacturers approved service places charge a reasonable price, but wont tell you anything for DIYers. I found a place in western canada that services them and does correspond with tips...that worked. And the obvious warning, the insides of a UPS can kill you if you dont take proper precautions
Jan 09, 2014 | APC Computers & Internet
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Why does the 4 outlets (surge only) of my cyberpower 685avr work while the 4 outlets with battery doesn't?
    May 08, 2011 | CyberPower Intelligent AVRLCD...
    Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
    Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
    Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
    Belkin f6h-350-usb-dl no power out in the upper row
    One set of outlets is surge protect and one row is battery backup. When you have a bad battery that row will not work. Remove the battery and test it.
    Dec 13, 2009 | Belkin (F6H350-USB) UPS System
    Belkin f6c750-avr repair / Testing
    You could be correct on the transformer. I'm kinda leaning towards a bad cell in the battery. Sounds like it will need replacing.
    Sep 03, 2009 | Belkin (F6C750-AVR) (BELF6C750AVR) UPS...
    Surge protectors
    No no need to charge there may loose contact between power cord and surge protecter or internal loose contact between sockets that can be removed
    Nov 12, 2008 | APC Back-UPS Office 500VA (BF500) UPS...
    Plugging an UPS into a surge arrester or plugging in a surge arrester into the UPS
    There should be no problem with what you are trying to do, one way or another. Just be sure not to overload your UPS (battery protected outlets). I myself have a power bar connected to my UPS to increase the number of battery protected outlets and everything works fine.
    May 31, 2008 | APC Computers & Internet
    UPS issues with bad power
    First, most of the UPS sensitivity can be adjusted. Setting a higher sensitivity will make the UPS compensable much faster if the current goes to high to too low thus always providing a good power quality to the equipments. For example, on a BackUPS RS the low level can be configured from 94V to 104V and the high level from 126V to 136V. An entry-level UPS such as the APC BackUPS ES will switch to battery mode as soon as the power goes out of the sensitivity range. On the other hand, a high-end UPS for workstation like the APC BackUPS RS has a feature called Automatic Voltage Regulation (AVR) that compensate at some extent without requiring the battery; this makes the battery last longer before needing to be replaced.
    Second, most of the UPS have "Battery Protected" and "Surge only" outlets. Make sure that the computers are connected to the "Battery Protected". The "Surge only" outlets will only protect from parasites or surges like a thunder storm. They should be used for less important stuff like a desk lamp or devices with high demand peek such as a laser printer.
    Third, the use of a power bar connected to the "Battery Protected" side should not have any impact as long as it is not overloading the UPS. Personnaly, I have a power bar connected to both my UPS.
    Feb 06, 2008 | APC Smart-UPS UPS System
    CyberPower 485VA UPS Backup (BE485) UPS System Logo
    62 people viewed this question
    Top CyberPower Computers & Internet Experts
    George Nalley
    Level 1 Expert
    Paul Bade
    Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
