Question about Bosch 1999 Dodge Ram 1500 Van Water Pump
Shifting problem in 1999 dodge 1500 it sometimes shifts ok, but getting bad. seems likewhen it warms up it wont shift into 2nd or 3rd. then stop and go in store and come out and it runs fine. what could it be?
  • 51 Answers
Check valve is stuck,you will need have it changed or removed. if you remove it it will take about 30 seconds when you start it up after sitting for several hours to go in gear. Because it has to get back up to pressure. It was a bad desighn by dodge because the check valve collects debris behind it and it restricts the fluid flow.
Posted on Jan 06, 2013
How to replace thermocouplr
below are 3 links to YouTube videos on how to change the thermocouple on a hot water heater, on the first 2 the guy removes the whole burner unit, the 3rd the guy replaces just the thermocouple.
the 1st & 3rd are standard heaters the 2nd is with a sealed Combustion Chamber
when I've replaced mine I just replaced the Thermocouple, but it is a little tight to get your hands in the small space.
https://www.youtube.com/watch?v=xGQngzqrIEE
https://www.youtube.com/watch?v=jDvo4yJ1OdE
https://www.youtube.com/watch?v=itTsykJQYzA
Aug 25, 2014 | Whirlpool Water Heaters
I have a Rheem 41VRP50N water heater. The water I am getting is luke warm on a good day. The burner fires up when I turn the thermostat to the highest temperature only. I drained the unit and flushed...
This condition can be caused by 4 different problems, or combination of these problems.
Good indicator would be to check temperature of water inside tank.
Put bucket under TP overflow tube and release water into bucket, then use cooking thermometer to gauge temperature. Stand back from scalding water that can shoot out of overflow.
If tank temperature is 120-130:
1) Crossover is suspect:
http://waterheatertimer.org/Crossover.html
If tank temperature is low:
2) Bad gas control valve thermostat is suspect.
I believe Rheem 41VRP50N has Honeywell or White Rodgers electronic gas control valve.
Open following link to identify gas control thermostat and see typical error codes.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Honeywell
Replacement gas valve can be purchased from Rheem.
3) Combustion parts and tubes need cleaning, and bleed gas line for air and water contaminants.
4) Water heater has sediment build-up coating burner transfer surface and covering thermostat.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Year of manufacture for Rheem water heater is 2nd two digits of serial number, so XX03.. would be 2003.
Add a comment and say what you did to solve problem.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Rheem Water Heaters
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
3rd yaco 006 in 3 years hot h20to hot
Taco circ. should be bronze in color for domestic applications. If it is green, it's wrong. Average temp for hot water should be 120 degrees. Overheating of circulator may be the cause of premature failure.
Mar 28, 2009 | Water Heaters
Upstairs rads r cold appears to be no pressure 2 vent rads
you have air lock in top floor rads must bleed it out start with the one closest to boiler and work your way out to what you figure is the end of line as best you can figure
Dec 03, 2008 | Water Heaters
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Bosch 1999 Dodge Ram 1500 Van Water Pump Logo
19 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
