Question about Apple iPad (16 GB) WiFi Tablet PC
My iPad is asking for a password to Netgear95; how can I find the password
I can't unlock my Ipad, it won't accept my password, how can i change my password
If you have synced your iPad with iTunes before you forget your password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked tablet while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Nov 23, 2016 | Apple iPad Tablets & eReaders
I have two iPads & my Twitter account works on one but not the other. When I log it, I'm told Password is wrong. I've changed password twice but it is never accepted on the 2nd iPad. Can you help?
You can use forgot password option in the IPad where your twitter account is not working properly.
Then reset your password and login to twitter using the same IPad which was having problem.
Getting started with Twitter for iPad
The last section of this link provides you with information on resetting your password.
If in case the problem persists then it must be an Apple problem.
Aug 29, 2015 | Apple Tablets & eReaders
Hi I forgot my password for my ipad
The biggest problem with Apple product's is the password. If you forgot your password you need to connect it to you PC/Mac and sync it with iTunes. From there it will ask you for your user I'd which is your email address and pasword. If you've forgot it you have the option to choose forgot password or user name. Either enter the user name and password or select forgot user name/password. If you remember it, it will sync with iclould and you can reset the iPad to factory settings with no password. Now the second option will send an email to you with a link to reset your password. The most important thing is that you remember your email address and password you signed up with when you bought the ipad. "If your in pad says Authorization lock....well you must have activated find my iPad or it is stolen and the iPad is bricked and there is no simple way of fixing this short of going to Apple with your proof of purchase.
Mar 01, 2015 | Tablets & eReaders
Just updated iPad 4 and now asking for VPN Authentification. I turned VPN off and it still asking for authentification.
I don't know your password but its request you ipad password to update or the program just would like to make sure that correct customer
Feb 26, 2015 | Apple iPad 4th generation
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Sep 07, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How reset ipad passcode
  1. Start the iPad
  2. Tap on the Settings app
  3. Tap on the Wi-Fi category
  4. Choose a Network
  5. Once you Tap on a network name, it will try to connect to it. If the network is using wireless encryption, though, you will be presented with a screen asking you to enter the wireless encryption password.
How to connect an iPad to Wireless or Wi Fi network
Aug 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
Aug 07, 2014 | Apple iPad 2 Wifi 16GB
Just bought an ipad mini i have a netgear router the ipad is asking for a password where do i find this?
Did you set up a password for the router? If you did not, then check on the user manual what default password the router has. Usually its 1234 or 12345678 or even a lot of numbers. Consider the back or bottom part of the router device. Sometimes manufacturers put the default passwords there.
Feb 02, 2013 | Apple iPad Mini
Apple iPad (16 GB) WiFi Tablet PC Logo
64 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
